13 hours on a one year oil change
   / 13 hours on a one year oil change #1
General Lee
Mid-Atlantic
Kubota L4400, B2401
Pitiful I know. My tractor use comes in spurts depending on time of year. Unfortunately, there is only 13 hours of use since my oil change a year ago. Should I change the oil, based on the one year and not the hours? It still is golden yellow
   / 13 hours on a one year oil change #2
I would, cheap insurance. When you so use it, is it for an hour or more? The hydro fluid may need to be changed based on time, not hours. Could have a condensation build up.
Most times its for an hour or more, not every time though. Condensation where? the oil crankcase or the Hydro crankcase?
   / 13 hours on a one year oil change #4
Yes, I'd change engine oil yearly, no matter the hours.
Trans oil I go by hours.
   / 13 hours on a one year oil change #5
As long as you run it an hour at a tume, the hst oil will be fine. Short runs can contribute to condensation build up.
   / 13 hours on a one year oil change #6
Both the hydro and the engine oil will draw moisture. The hydro oil will absorb a considerable amount of moisture but the engine oil also builds up acids. The oil could be fine and you could do a oil analysis to see if it needs changed but that would likely cost as much as an engine oil change. I would change the hydro by the hours and maybe do a crackle test on a hot plate to see if has drawn excessive moisture.
   / 13 hours on a one year oil change #7
Do you run it throughout the year or does it sit for long periods. If you run it all year than I would not worry about the oil. Change it if it sits for months at a time.
   / 13 hours on a one year oil change #8
The one-year oil change recommendation is based on the fact that the additives lose their beneficial properties over time whether the engine is running or not. The base oil is stable and will stay the same, but running it will be more like running non-detergent oil.
   / 13 hours on a one year oil change #9
I wouldn't change it until just before you put it away this fall. 13 hours is such a small time that the oil is essentially new. Just a waste to change it. When is the last time an engine failed due to a tiny exposure to acid? That is essentially a hypothetical concern IMO and not worth wasting perfectly serviceable oil over.
   / 13 hours on a one year oil change #10
So your saying that you should not store oil for more than a year.:confused3:
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
PALLET OF DRAINS / DRAIN GATES (A51244)
PALLET OF DRAINS /...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
Gleaner R50 Combine (A50514)
Gleaner R50...
