12v power supply
/ 12v power supply #1
Mac25
Danville, IN
Kubota B2320 HST with LA 364 FEL
Not sure what to use it for.......possibly a cell phone charger or something, but I had it laying around the garage and decided to mount it. I used the dead plate next to the PTO and 3 pt hitch levers for the location.
/ 12v power supply #2
I added a 12v outlet to my Deere 4400. The first use will be for a warning light to be mounted on my ROPS. See the attached picture.
I'm sure I'll find other, occasional, uses...
/ 12v power supply #3
I use mine to plug in a float charger (I added a 12 v plug to the charger) as well as a flashing light for use on the road.
/ 12v power supply #4
You'll find many uses for a 12V outlet. Is it fused? I would think 5 amps minimum and no more than 10 amps. What gage wire did you use? I think it's a great idea, but as you can tell, I have lots of questions.;)
/ 12v power supply #5
I used an inline fuse (10 Amps) and ran from the battery to the panel just below the ignition switch.
I did a thread on this:
http://www.tractorbynet.com/forums/john-deere-owning-operating/217876-adding-12volt-outlet.html
I used a Marine type outlet and plug for making it as weather proof as possible. You can buy automotive style inline fuses at any hardware or auto parts shop.
One thing I would have done differently is use 12 gage wire rather then the 14 gage I did use. All terminals were crimped and the run of the wires is in a heat resistant sheath. I wiretied the sheath about every 10-12 inches.
My installation is to power a warning lamp (see post #2).
/ 12v power supply
I have not actually wired it yet, but will probably use 12 gauge wire as well as some type of fuse as stated.
/ 12v power supply #8
My Kubota came stock with 12 volt power outlet.
Patrick
So do some of the Deeres...but if one has an older tractor (my 4400 was built in 2000), the only way you'll get one is install it yourself.
/ 12v power supply #9
The inline fuses I found had 12 gage pigtails...so I had to crimp 12 gage in one end, 14 gage in the other end...not my preference, but I had all ready ran the rest of the wiring....one reason I'm posting this (and I had posted the same in that linked thread). No use making the same mistake I did...
Time will tell if that 12 to 14 gage terminal will hold up.
/ 12v power supply #10
/ 12v power supply #11
At ten amps, 14 gauge is plenty, for that matter you could fuse 14 at 15 amps with no problem. The male portion that you plug into the power outlet may be another matter. Most are either meant for short heavy loads Ie cigar lighter, or lighter long loads such as cell phone charger. Buy the best you can find if you are making something up....
/ 12v power supply #12
Jinman,
Doesn't your New Holland have one? My 2006 TC40DA has one on the floor behind the seat on the right side. Bad location for it in my opinion as all the junk (chains, tools, etc) I throw behind the seat broke the little plastic cover off and now it is full of dirt and rust.
/ 12v power supply #13
Handheld spotlight immediatly comes to mind. My work lights dont point off to the sides...
/ 12v power supply #14
/ 12v power supply #15
One thought is a inverter if needed in some remote location would make that power supply handy.
/ 12v power supply #17
For an inline fuse, all the ones I found used 12 gage wire for the pigtails (as I'd previously written). Probably better to use the same wire gage throughout and especially if the run needs an inline splice (inline fuse pigtail to the rest of the wire) like mine did.
/ 12v power supply #18
Jinman,
Nope! That was something that came with the "DA" models. I've often thought of putting one in, but for now it's "coulda, woulda, shoulda". . . I'm the king of procrastination.:eek:
/ 12v power supply #19
Watts are watts regardless of the source. 10A at 14VDC after factoring in inverter efficiency is only going to power about 120Watts of AC load... Any surge on an inverter would snap that 10A fuse like a toothpic:)
An inverter that is going to be worth anything needs to be hardwired to the battery with short, FAT cables to handle surge and startup currents. But it will only be able to sustain a load = to the alternator's output to the battery... As an example, a 60A alternator could sustain a 700W load on a properly wired inverter.
/ 12v power supply #20
Good points!
These outlets are very nice convenience items, just as they are in a car or truck, if you need to charge a phone, laptop or something of that nature.
But, not a substitute for a PTO generator...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
ALLMAND MAXI-LITE II V-SERIES (INOPERABLE) (A68842)
ALLMAND MAXI-LITE...
2025 48in. Farm Jack (A66734)
2025 48in. Farm...
Sandblast Pot (A68134)
2012 HINO 258A CAB AND CHASSIS(INOPERABLE) (A67714)
2012 HINO 258A CAB...
2019 CATERPILLAR 259D SKID STEER (A65056)
2019 CATERPILLAR...
