12v fan source?
/ 12v fan source? #1
daveinnh
Hillsboro, NH
Kubota L4310
I have a Curtis cab on my Kubota L4310. The fan I put in 3 years ago (bought new but sitting on a shelf for a few years for $20) sounds like its about ready to retire - noisy and needs a push start w/ a screwdriver occasionally. The fan is mounted on a ball and can be rotated to suit need.
The price for a new fan from Curtis is ~ $115 from a local dealer. Grainger offers one for $74 w/o shipping.
Is that the going rate?
/ 12v fan source? #2
You can look in the JC Whitney catalog and find one for under $30.
/ 12v fan source? #4
I may be way off base here, but I think I'd try a small plug-in inverter and a small clip-on AC fan you can buy for about $15. I have several small inverters that plug into my cars cigarette lighter. I'll check their power rating, but I think it's enough to run a small fan.
/ 12v fan source? #5
Try oiling fan motor with a silicone spray to get more life out of it.
/ 12v fan source? #6
its that old story, you get what you pay for (most of the time) I would check with your local parts store, or truck supply store and check the price of the better grade. I have tried the JC Whitney and those other $30 fans. They may last a few months, then another $30. Buy a good fan and keep it lubed and cleaned.
/ 12v fan source? #7
go to a NAPA parts store the have them in stock or they can have it the next day
/ 12v fan source? #8
If lube won't fix the fan, consider replacing the bearings/bushings on both ends of the armature. Provided you don't wait until it had gone too far before replacing the bearing/bushings, you should be able to get a little more life out of it.
David from jax
/ 12v fan source? #9
Try West Marine. A good marine fan will last as they are usually sealed.
jb
/ 12v fan source? #10
Buy a 4" computer 'muffin fan', they are all ball bearing designed and are merely 1" thick.
The big bonus is that they draw less than 1 amp and also push a lot more air than paddle blades.
They generally are available in 12VDC as well as 110AC.
Also MUCH more compact.
Good luck, Ebay should be a good source.
Expect to pay about $10.00
/ 12v fan source? #13
If you want to find it online, try surpluscenter.com, last time I looked they had a whole page full of 'em.:cool:
/ 12v fan source? #14
How about a fan from pulled from an automobile heater? You could even get creative and pull the heater core and plumb it into your cooling system for winter heat.
2020 International LT625 48" Sleeper (A62613)
2020 International...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
