12v AC For Headlights?
/ 12v AC For Headlights? #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
In another thread here, I mention restoring my 1984 Wheel Horse garden tractor. One of the items on my 'To Do' list was to get the headlights working. I thought it'd be as easy as running a replacement wire from what was left of one that was damaged up to the headlights. It proving not to be so easy. /forums/images/graemlins/frown.gif
According to the wiring diagram, there's a Diode (Rectifier) near (in?) the engine that has 2 outputs. one of which is labeled A.C. for Lights. This wire goes to a toggle switch on the console. The other wire on the toggle switch goes to the headlights (this is the wire I have to replace). I checked the voltage at the diode and it only reads about 5.5 volts which is not enough to power the headlights.
Does this mean I have to have the engine serviced in some fashion?
Why would the lights run on AC?
/ 12v AC For Headlights? #2
I don't know about yours, but mine only has power in the lighting circuit when the engine is running. There is a small alternator under the flywheel, that is for battery charging and running the lights. /forums/images/graemlins/crazy.gif
/ 12v AC For Headlights? #3
<font color="blue"> Why would the lights run on AC </font>
I haven't seen it all, and there are some wacky setups out there, but I can't imagine that a small engine is going to use AC for low voltage lights. Did you take the reading with the engine running or not? And was it cranking at high enough RPM to get a generator / dynamo to put out power? Sounds like Slamfire may have your answer...no voltage there until you're generating enough power?
/ 12v AC For Headlights? #4
I feel for you /forums/images/graemlins/frown.gif
I just totally rewired my Murray and it was apain thta took entirely too long. My friend helped and he is an electrician but we still had probles with all the safeties and other unecessry garbage.
I looked at my schematics and the only AC power was comingoff the stator in the form of a black AC wire that goes to a diode and comes out a white AC wire /forums/images/graemlins/confused.gif
Are you SURE Ac went to the lights? My lights also only work when the tractor is running.
Sorry i can't be much of a help. We ended ripping everything out and wiring it in a logical fashion, minus all the extra junk.
Attached is the wiring diagram for the tractor. The upper left and upper center portion shows the lights circuit. The lights only work when the engine is running and that's when I tested the output from the 'dark green' wire.
/ 12v AC For Headlights? #6
I have worked on a couple of older Briggs engines that actually had 2 windings in the flywheel alternator. ! came out as AC for the headlights and the other one was rectified to DC for the battery. Be careful and only use the proper wattage bulbs in the headlights, otherwise you can fry your headlight alternator winding. Also these AC voltage readings may be deceptive when not hooked up to a load ie headlight bulb. And may not be 12 V at all engine speeds. The ones I worked on seemed to vary a lot with engine speed.
<font color="blue"> Also these AC voltage readings may be deceptive when not hooked up to a load ie headlight bulb. And may not be 12 V at all engine speeds. The ones I worked on seemed to vary a lot with engine speed. </font>
Do you think the headlights might work if I just connected everything per the wiring diagram? I checked the B & S website and the regulator for my engine is $70.25! /forums/images/graemlins/shocked.gif
I know the lights work since I connected them directly to the battery to test them and I checked the toggle switch with my digital VOM.
/ 12v AC For Headlights? #8
Mike,
I think that would be ok if they are origional or origional replacement types. If the lights are not origional types they might draw too much current and damage the alternator in your engine. The AC should be tapped off before the actual rectifer circuit and should not effect the regulator/DC voltage unless the headlights are drawing too much current ie not origional types. The Briggs manuals I have seen say to ONLY use the proper head lamp bulbs or damage can occur.
slowrev, these headlights are original equipment I got from my Toro/Wheelhorse dealer.
When I read the 5.5 AC volts at the rectifier, the engine was at idle. Assuming I have not misread (entirely possible /forums/images/graemlins/grin.gif) your post, as I increase the rpms the voltage should come up?
Also, would there be a problem with powering these lights from the DC side of the tractor's electrical system?
/ 12v AC For Headlights? #10
Yes you are correct the lights will probably be pretty dim at idle and brighter as the rpm's go up. Not sure on the battery powering of the lights. The alternator/regulator might not handle the added current, or might, but at 70.00 or so a regulator I don't think I would want to chance it. I would just hook them up as they were, I have only used mine on any rider or tractor once or twice a year anyway. Just rev it up a bit and they brighten right up.
/ 12v AC For Headlights? #11
<font color="blue"> Do you think the headlights might work if I just connected everything per the wiring diagram? </font>
Yes.
<font color="blue"> Yes </font>
It did! The Wheelhorse is all back together with working headlights.
/ 12v AC For Headlights? #13
One of the problems that develops in the magneto circuit is weakening of the permanent magnets. Alternators work kinda the same way, could the magnet in that circuit be feeling it's age?
/ 12v AC For Headlights? #15
Mike, I also have a 1984 Wheel Horse GT-1100 that i purchased new. One of the first changes was cutting the headlight wire and replacing the headlight switch with a SPDT switch that uses the original AC wire in the up position and 12v DC from the battery in the down position. The dealer said they used the AC for lighting because of the low output of the alternator (5 amps if I remember right). It is normal for the light to be dim when you are at less tham maximum RPMs. Hope this helps, Bill C
Thanks, Bill. I got everything all wired up again. My GT-1600 is back in service! /forums/images/graemlins/cool.gif
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
New/Unused Landhonor 72in Rock Bucket with Teeth (A65583)
New/Unused...
2017 GEHL RS6-34 TELEHANDLER (A62613)
2017 GEHL RS6-34...
2019 RAM 5500 4X4 S/A ROLLBACK TRUCK (A59914)
2019 RAM 5500 4X4...
2021 John Deere 5100E (A64126)
2021 John Deere...
ATS Mini Excavator ATS - ME18 (A66285)
ATS Mini Excavator...
