12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #1
Rightsaidfred
McCormick CX100 XtraShift
Hi Guys, I'm in Canada, and looking for a 12mm pipe plug/drain plug socket for the 4 drain plugs on the T25 front axle.
Im not a fan of using open ended crescent wrenches on hard to remove plugs, inevitably they get gauled up
Looking everywhere I cant find a 12mm. I find 10mm and lots of SAE, but no 12mm
Anyone have a source for one ?
Cheers
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #2
Would using an adjustable wrench, tightened up as tight as possible, work for you ? Not much chance of that slipping off while using it .
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #3
That axle should be low to no pressure behind the plug. Once you get it out replacing it with a normal 6 sided "plug" of the correct thread should be pretty simple.
Then you could just weld a normal nut to your factory plug.
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #4
Will a 1/2" open ended wrench fit? 12mm is really close. If there's too much slop I agree with BleedingOrange, just use the biggest open ended adjustable you can find.
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #5
He said it's F E M A L E !
Grind down a 1/2" extension and get it done.
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #6
...well I just happy that I'm not the only one with difficulties speed reading. 😆
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #7
8 pt socket?
Exactly what I need. Aliexpress here I come.
The plug is male and I need a female socket.
A 12mm open wrench fits snug, but Im not a fan of using them on very hard to remove items, even less of a fan of adjustable. (even metric adjustable ones LOL)
Cheers for all the suggestions guys
thank you
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #10
Ah sorry, I completely missed the female part, hidden in the title. Ya, I might be tempted to grind down an old 1/2 short extension, so it just fits very snug into the female head.
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
Ez-Go Shuttle 2 Electric Golf Cart (A50121)
Ez-Go Shuttle 2...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
New Idea 483 Round Baler (A50774)
New Idea 483 Round...
Honda HT3813 Riding Mower (A50121)
Honda HT3813...
