12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #1
Rightsaidfred
McCormick CX100 XtraShift
Hi Guys, I'm in Canada, and looking for a 12mm pipe plug/drain plug socket for the 4 drain plugs on the T25 front axle.
Im not a fan of using open ended crescent wrenches on hard to remove plugs, inevitably they get gauled up
Looking everywhere I cant find a 12mm. I find 10mm and lots of SAE, but no 12mm
Anyone have a source for one ?
Cheers
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #2
Would using an adjustable wrench, tightened up as tight as possible, work for you ? Not much chance of that slipping off while using it .
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #3
That axle should be low to no pressure behind the plug. Once you get it out replacing it with a normal 6 sided "plug" of the correct thread should be pretty simple.
Then you could just weld a normal nut to your factory plug.
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #4
Will a 1/2" open ended wrench fit? 12mm is really close. If there's too much slop I agree with BleedingOrange, just use the biggest open ended adjustable you can find.
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #5
He said it's F E M A L E !
Grind down a 1/2" extension and get it done.
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #6
...well I just happy that I'm not the only one with difficulties speed reading. 😆
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #7
8 pt socket?
Exactly what I need. Aliexpress here I come.
The plug is male and I need a female socket.
A 12mm open wrench fits snug, but Im not a fan of using them on very hard to remove items, even less of a fan of adjustable. (even metric adjustable ones LOL)
Cheers for all the suggestions guys
thank you
   / 12mm Female Square Drain Plug/ Pipe Plug Socket ?? TYM Front axle drain & Vent pugs #10
Ah sorry, I completely missed the female part, hidden in the title. Ya, I might be tempted to grind down an old 1/2 short extension, so it just fits very snug into the female head.
2005 Ford Explorer 4x4 SUV (A42744)
2005 Ford Explorer...
John Deere 330C LC Excavator (A42021)
John Deere 330C LC...
2019 FORD  F350 (INOPERABLE) (A45046)
2019 FORD F350...
2017 ADDCO ROAD SIGN DH1000-ALS (A45046)
2017 ADDCO ROAD...
WICHITA TANK 500BBL WHEELED FRAC TANK (A45046)
WICHITA TANK...
2018 Terex RL4 Towable Light Tower (A42742)
2018 Terex RL4...
