1210 case with no hydraulics but has psi
   / 1210 case with no hydraulics but has psi #1
ERockingFarms
Hamilton Ohio
1210 David Brown/ Case 1979
I have a 1978 case that has the pressure from the pump to lift and use to lift a 7 foot bush hog we have been using. i have had the pressure tested and it checks out fine, and the tractor tries to lift when you push the lever to take the hydraulics up but now only picks the front of the deck up compared to being able to pick up the whole bush hog without a problem. i think the three way control valve has issues but am not sure and do not want to take it apart until i get a few other ideas
   / 1210 case with no hydraulics but has psi #3
Sounds like you have a leak in the 3pt lift cylinder.
Does the tractor have remotes and if so, are they working properly?
Need more info to better help.
Mark
   / 1210 case with no hydraulics but has psi #4
I've attached a parts breakdown below.
Item 17 and 18 are what you need if the 3pt cylinder is bypassing.
Mark
  • 8-34 RAMSHAFT AND RAM CYLINDER.pdf
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
