1210 case with no hydraulics but has psi
   / 1210 case with no hydraulics but has psi #1
ERockingFarms
Hamilton Ohio
1210 David Brown/ Case 1979
I have a 1978 case that has the pressure from the pump to lift and use to lift a 7 foot bush hog we have been using. i have had the pressure tested and it checks out fine, and the tractor tries to lift when you push the lever to take the hydraulics up but now only picks the front of the deck up compared to being able to pick up the whole bush hog without a problem. i think the three way control valve has issues but am not sure and do not want to take it apart until i get a few other ideas
   / 1210 case with no hydraulics but has psi #3
Sounds like you have a leak in the 3pt lift cylinder.
Does the tractor have remotes and if so, are they working properly?
Need more info to better help.
Mark
   / 1210 case with no hydraulics but has psi #4
I've attached a parts breakdown below.
Item 17 and 18 are what you need if the 3pt cylinder is bypassing.
Mark
  • 8-34 RAMSHAFT AND RAM CYLINDER.pdf
Club Car Electric Cart (A55758)
Club Car Electric...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
2021 Deere 333G (A53317)
2021 Deere 333G...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
