1200 Ford... Any ideas for repair ?
   / 1200 Ford... Any ideas for repair ? #1
Agent Blue
Platinum Member
I know of a 1200 Ford with a broken crankshaft that is for sale. I have been searching the internet for over a month and haven't come up with an engine or crankshaft. One site has an advertised price of $1000. for the crankshaft but has none in stock. Anyone aware or a replacement engine that could be refitted ? I realize they are 20 plus years old but with a mmm and fel it would serve a useful purpose if repairable. What would be a suitable price for a machine in this condition ? My luck would be a transmission gear shattering after replacing an expensive diesel engine.
   / 1200 Ford... Any ideas for repair ? #2
Actually at least 26 years old if not more.
Here is tractordata.com info on 1200
Ford 1200
General tractor information:
Distributor:Ford
Manufacturer:Shibaura
Model:1200
Type:Farm/Agricultural tractor
Series:Hundred series compact
Years produced:1979 - 1982
Total built:
Factory:
Original price:$6,513 (1982)
Tractor power:
Engine:16 hp [11.9 kW]
PTO (rated):13.5 hp [10.1 kW]
Engine:
Fuel:diesel
Cylinders:2
Bore/Stroke:
Displacement:49.5 ci [0.8 L]
Compression:
Rated RPMs:
Cooling:liquid
Torque:
Firing order:
Transmission:
Type:
Forward:10
Reverse:2
Mechanical:
Chassis:4x2 2WD
4x4 MFWD 4WD optional
Steering:
Brakes:
Capacity:
Fuel:
Power Take-off (PTO):
Rear PTO:transmission
Rear speed (RPM):540
Tires:
Ag front:6-12
Ag rear:8-16
Dimensions:
Weight:1,244 lbs [564 kg]
   / 1200 Ford... Any ideas for repair ? #3
The crankshaft is still listed as available from New Holland Parts. The costs from Messicks web site for a new one is:
CRANKSHAFT SBA115256180 Superseded By : SBA040116001 ?? on superseded number $848.09
Availability 3-5 days
To me the tractor in the condition it's in is probably not worth more than a few hundred dollars and that is if you have a lot of personal time to invest.
Andy
I think this one is better parted out than repaired. No one knows the condition of other expensive related parts. Thanks for the reply Andy !
   / 1200 Ford... Any ideas for repair ? #5
Thanks
And I agree with your conclusion.
Andy
TROYBILT TBE252 GAS POLE EDGER (A51248)
TROYBILT TBE252...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
(INOP) CATERPILLAR 914G WHEEL LOADER (A51247)
(INOP) CATERPILLAR...
Wacker Neuson G25 20kW Towable Diesel Generator (A51691)
Wacker Neuson G25...
