12 Volt socket added...
/ 12 Volt socket added... #1
KrisHansen
Vermont
New Holland TC33d
yeah, nothing really exciting, but I really wanted a 12v outlet somewhere on my tractor.. wired it to constant power, with a fuse.
Now I can run my cool rotating light when I am trundling along the road at some slow speed...
/ 12 Volt socket added... #2
I did a similar thing on both the TC24 and the B2910 It is a useful thing to have sometimes. Mine are both mounted in the rear by the base of my ROPS so I ran the power through a switch simply because it was inconvenient to pull the plug to shut off whatever it is that I am powering. I've used it many times with a 12 volt sprayer and the switch really comes in handy for that application.
12 Volt outlet on TC24
/ 12 Volt socket added... #3
Kris / Bob handy setup. Thinking of doing the same with my tractor.
Kris: Not to hijack the thread but......I noticed the chains. I would like to get a set for myself. Who manufactured yours and do they have a web site. As well did you have any problems with clearance?
/ 12 Volt socket added... #4
Kris when your not out cruising the open road you can use that plug for your electric shaver. Get a quick shave to go. /forums/images/graemlins/grin.gif
The chains are OFA Hakkis.. My local dealer got them. They are simply put, amazing. Very heavy, very tough. I managed to bend one of the links, but otherwise, I LOVE them. Prepare to get a workout putting them on, but otherwise, they work great in snow/ice/mud. If you Google it, you won't find a lot of hits.. But, they are great chains.
</font><font color="blue" class="small">( Kris when your not out cruising the open road you can use that plug for your electric shaver. Get a quick shave to go. /forums/images/graemlins/grin.gif )</font>
Heh, this winter, i'd rather hook up some sort of heated seat/snowmobile suit... Hey, that's not a bad idea! :-D
/ 12 Volt socket added... #7
I could use one of those myself! My 455 fills behind the seat like the NH does, but the Deere CUT's fill thru the hood. I HATE filling with cans and plan to add a storage tank/pump, but some times it is necessary to fill in the field. I've got a smal electric pump that I plan to use rather than spilling all over, and an outlet like this would work well!
/ 12 Volt socket added... #8
Kris, that's a very nicely made 12V socket. I especially like the spring-loaded weather cover. /forums/images/graemlins/cool.gif I can see the brand is Casco, but where did you get it?
/ 12 Volt socket added... #9
I did a search for OFA Hakks and only got the post John did from TBN on the chains.
murph
/ 12 Volt socket added... #10
There are two different Casco sockets, one like Kris's and the other is attached with 4 small screws. I would like to know where Kris got his also. I bought mine at Wal-Mart. They have both styles at some stores.
I got that socket at my local AutoZone. Very inexpensive, like around $12...
Murph, try Google on OFA Hakki
There don't seem to be many web stores for those things, but that's probably 'cause no one in their right mind would mail order 300 lbs of chain!! /forums/images/graemlins/grin.gif
/ 12 Volt socket added... #13
Nice tidy install. Not to rub it in, but my Case came with one factory installed. /forums/images/graemlins/smirk.gif
/ 12 Volt socket added... #14
</font><font color="blue" class="small">( Nice tidy install. Not to rub it in, but my Case came with one factory installed. /forums/images/graemlins/smirk.gif
)</font>
Not to rub it in, but I bet if you knew the cost for that socket that was hidden in the price of your Case, it would be much more than $12. /forums/images/graemlins/smirk.gif /forums/images/graemlins/smile.gif
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2021 MULTIQUIP WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
