12 volt power source
   / 12 volt power source #1
n219ct
Essex, MA
JD 4320
Hi,
I have a 2005 4320 and I am adding a Fasse diverter valve to my third hyrdraulics. I need a 12 Volt power source back there to operate the switch.
I noticed a wire stubbed out right behind the seat and it has a small clip-on adapter attached to the end. The adapter seems to loop the the wires back on themselves. Does anyone know if this is a 12 volt power source for auxiliary electronics and does JD sell a part to clip right in to it rather than splicing and taping it?
Thanks in advance,
John
__________________
   / 12 volt power source #2
I think that may be for the optional work lights, but you will have to test it with a VOM or testlight to be sure.
   / 12 volt power source #3
That is for the worklight and it will only be "live" when the light switch is in the correct position (symbol with downward facing beams). I fabricated a bracket to mount a single 12 volt light I had laying around to the rollbar, centered behind the seat, which I use for snowplowing at night with a rear blade. This works pretty good but I would like it if there was a light switch position that would allow the flashers and the worklight to be operated at the same time. If I get time this winter I will run power from another source and install a seperate switch to make that happen.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A54865)
IMPORTANT PLEASE...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A55787)
2025 GIYI GY-BK56M...
2018 KUBOTA SVL95-2S SKID STEER (A52705)
2018 KUBOTA...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
UNUSED DIGGIT EM15 EXCAVATOR (A54756)
UNUSED DIGGIT EM15...
