12 volt heater
/ 12 volt heater #21
FCOL! This is not a VW forum!
/ 12 volt heater #22
/ 12 volt heater #23
We had one beetle, one Karmen Ghia, and 4-5 buses. I remember my dad "fixing" the long rusted heat pipe from the engine to the front with dryer vent pipe on a couple of the buses. :laughing:
On really cold days the inside of the windows would frost up from our breath. We'd always crack the wing vent windows open to blow on the windshield. You really got to appreciate good, warm clothes if you owned a VW in the winter. :thumbsup:
The beetle had gasoline heater.
/ 12 volt heater
Today I put the 300 watt heater to the test. As my cab comes off 1st thing in the spring I have no desire to have hoses or a permanent heater my main objective was to see if a 12v. would actually make any difference as I'm happy with the fact I even have a cab for winter. I have a glue on oil pan heater and spent yesterday installing a block heater so didn't do the test until this morning. Here's the results.Out side temp.
Turned on the heater then checked temp. for it.
Drove up the mt. for an hr. no gloves or long under wear jacket open cool but not cold. Top of cab is sealed well but not around the bottom area. Temp. in cab when I got back far from hot but warmer than outside.
The engine didn't get very warm either.
Worth it ? but at least anyone considering buying on new can know what to expect. At colder than when I did the test there would be very little improvement if 10 degrees warmer I'm sure there would be a noticeable dif. in temp.
/ 12 volt heater #29
I go out here in Maine dressed for AK, Hot Hands insole warms and all I haven't been cold in my cab, the wind is the killer so a cab is a must..
/ 12 volt heater
Both the last posts sound like very good options. A young friend worried about an old man phoned me to tell me heated jackets were on sale 1/2 price a few wks. ago.
/ 12 volt heater #31
Engine coolant cab heater with quick connects and add a cover to the radiator when cold would not be too difficult to do. Temp. Controlled shutters would even be nicer.
There was a time we changed thermostats for summer to winter.
/ 12 volt heater #32
I also put hand warmers in my gloves.. If it's below 10F and I need to remove snow it takes me two hours and if that's the case I will through on my Artic Cat snowmobile suit with my 100F below Kamik boots with the warmers, it's a little bulky but I don't get cold, I can stay out all day comfortably if I dress for it..
/ 12 volt heater #33
That's what I'd do. Our IH2500b had a cab heater. It was a little round core with a blower fan inside it. Two radiator hoses ran to it. There was a valve at the block where you could turn it off for summer and on for winter.
My 1971 Toyota FJ40 Landcruiser has a rear heater that is very similar.... two coolant hoses to a heater core with fan.
It would be very easy to put fluid quick connects on the hoses outside the cab so it could be disconnected when the cab is removed for summer.
/ 12 volt heater #34
Common air hose fittings work fine for such applications, and are not costly at the local autoparts store.
/ 12 volt heater #35
I have a Gerbing heated jacket so gonna hook up the the adaptor and wear that!
No cab on my tractor. Been wearing Gerbings jacket liner, gloves and heated insoles for years. When using the blower I also wear my motorcycle helmet.
/ 12 volt heater #38
I turn the chute away from me....:laughing:
I had to laugh at that one. :laughing:
I've been using a plow on mine for 15 years. I've been snow blowing my in-laws drive this year as my FIL is 89 and had some surgery, so he can't do it this year... I'd forgotten that every time you turn around with a blower the snow's gonna come back in your face! :rolleyes:
/ 12 volt heater #39
The exhaust heat re-claimers used on air cooled engines to heat air craft interiors are effective on ground based vehicles too.
2025 SDLANCH SDL2030GT Heavy-Duty Greenhouse Tent (A64194)
2025 SDLANCH...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
