12 V DC to 120 AC inverter for field work.
   / 12 V DC to 120 AC inverter for field work. #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Hello,
Anyone have experience running an AC skilsaw off a 12volt inverter? This saw is 15A@120V. Do they have reasonable power? Does either component burn out? Thanks,
John
   / 12 V DC to 120 AC inverter for field work. #2
I've run a Statpower 2000 watt inverter in my service van over 20 years...
It will run a 15 amp skill saw if everything is set up right.
I use a skill panel saw 95% of the time which is less than half the draw and contrary to what everyone said... will cut 2x material all day...
You will need a quality inverter AND large copper cables AND sufficient battery power to make it work... I have a second RV batter set-up with a added continuous duty golf cart solenoid that allows both starting battery and second battery to be joined... like using jumper cables... only at the flick of the switch.
When I need to run near the max, I also keep the engine running which makes a lot of difference... also swapped out the stock alternator for one designed for ambulance service... still single pulley, 130 amp and pully for more power at lower speed.
I would think running a skill worm saw all day with a generator might make more sense if only to keep time off the engine.
   / 12 V DC to 120 AC inverter for field work. #3
15 amps at 120v is 1800 watts. A inverter that size will run you $150-500. You would be better off getting a generator for $150 on Craigslist and putting that in your bucket or on a carryall.
Aaron Z
   / 12 V DC to 120 AC inverter for field work. #4
Aaron Z
I paid over a $1000 20 years ago~!
   / 12 V DC to 120 AC inverter for field work. #5
   / 12 V DC to 120 AC inverter for field work. #6
It's amazing how much prices have come down...
I bought mine at West Marine and at the time, the sine wave model was $2500...
Did learn one trick that I should mention...
On my inverter... it will go to sleep if there is no load... not a problem if starting a small load.
On a full load, it will trip the safety and show overload which requires turning off and then on to reset.
I have a 60 watt light bulb plugged into the other outlet and this draws enough to prevent sleep mode...
   / 12 V DC to 120 AC inverter for field work. #7
Aaron Z
Also don't forget that the inverter is not 100% efficient. It may be close to 90% when running at maximum load. Somewhat less with smaller loads. But lets say it is 90%, so the output side as Aaron pointed out is 15 amps * 120 volts=1800 watts. So .9X=1800 X=2000 watts on the input side. Now if we can maintain an actual 12 volts under this load, we would be lucky, so lets figure the approximate current draw in Amps. So E * I=P Volts * Amps = Power in watts.. 12 * I=2000.. solve for I.. equal 167 AMPS (rounded).. so that is a bunch of Amps. About like the starter on your tractor cranking all the while that saw is running. You need really big wire, really clean low resistance connections and a really good battery and enough time in between cuts for the alternator to catch up and recharge that suffering battery. Remember starting batteries are NOT designed to be run down, like stationary or marine service batteries are. Even one run down can shorten the life and reduce the capacity of a starting battery. In my opinion you would be better off with a small generator.
James K0UA
   / 12 V DC to 120 AC inverter for field work. #8
Let's do the math shall we.. :)
Lets say you have the 60 amp alternator in your L4330,
That's 60 amps at 14 volts or about 840 watts output max, your skill saw draws 1800 watts at 120 volts, figure some overhead for the inverter and you're drawing around 1000 watts from the battery (80 amps or so) on top of what the alternator puts out.
Your tractor takes a 75amp-hour battery, it's only safe for the battery to draw half that power so you have about 500watt-hours to use before you have to stop working.
So with the engine running, starting with a completely topped up battery you can run the saw continuously for 30 minutes before you have to stop working, it will take at least 20 minutes (But most likely more) to top the battery back up once you do this though.
So in summary, cutting a few fence boards at a time and letting the tractor run in between it'll work just dandy but don't plan to sit down and cut for extended periods.
   / 12 V DC to 120 AC inverter for field work. #9
James K0UA
Good points, but remember the saw will not be pulling full current all the time. Let is startup unloaded and then cut gently. It still can be a lot of current of course. It might make more sense to get a battery power saw.
   / 12 V DC to 120 AC inverter for field work. #10
James K0UA
Good points, but remember the saw will not be pulling full current all the time. Let is startup unloaded and then cut gently. It still can be a lot of current of course. It might make more sense to get a battery powered
saw.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
