Oil & Fuel 110 TLB Transmission Oil ?
   / 110 TLB Transmission Oil ? #1
RaytheOne
KY
JD 323D
I have a 2010 model 110 TLB. The owners manual specifies factory fill is regular Hy-Gard. However, the dipstick says to use Low Viscosity Hy-Gard. Called my dealer, who contacted Deere, and he didn't get any real answer. I understand the difference between the two, but trying to figure out why the discrepancy between the manual, and the dipstick. :confused:
As much as they may be compatable with one another, doesn't seem like you would want to mix them.
The salesman and I wondered if it makes a difference where the machine was being shipped to. Cold climates get Low-Vis oil???
Just wondered if anyone else has run into this?
   / 110 TLB Transmission Oil ? #2
I think your overthinking this way too much. In cold temps Lo Vis. Warmer temps regular. I wouldn't mix them but when you change it just buy a little extra and flush it good. My tractor came with lo vis and I use the regular stuff. Just look at your owners manual and the Hyguard temp chart and see where you fall.
Matt;)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2012 Ram 5500 Service Truck, VIN # 3C7WDMDLXCG124340 (A51572)
2012 Ram 5500...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
