Oil & Fuel 110 TLB Transmission Oil ?
   / 110 TLB Transmission Oil ? #1
RaytheOne
Bronze Member
KY
JD 323D
I have a 2010 model 110 TLB. The owners manual specifies factory fill is regular Hy-Gard. However, the dipstick says to use Low Viscosity Hy-Gard. Called my dealer, who contacted Deere, and he didn't get any real answer. I understand the difference between the two, but trying to figure out why the discrepancy between the manual, and the dipstick. :confused:
As much as they may be compatable with one another, doesn't seem like you would want to mix them.
The salesman and I wondered if it makes a difference where the machine was being shipped to. Cold climates get Low-Vis oil???
Just wondered if anyone else has run into this?
   / 110 TLB Transmission Oil ? #2
I think your overthinking this way too much. In cold temps Lo Vis. Warmer temps regular. I wouldn't mix them but when you change it just buy a little extra and flush it good. My tractor came with lo vis and I use the regular stuff. Just look at your owners manual and the Hyguard temp chart and see where you fall.
Matt;)
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
SET OF TRUCK FENDERS & HARDWARE (A58374)
SET OF TRUCK...
2245 (A58376)
2245 (A58376)
2014 JCB 930 (A57148)
ALLISON TRANSMISSION (A55745)
ALLISON...
