Sep 7, 2023 / 110 tlb deere overheat #1 C coqui Member Joined Apr 6, 2020 Messages 26 Tractor toolcat 5600 anyone have an overheat caused by hydraulic oil cooler mounted in front of radiator. been through head,water pump,radiator,thermostat
Sep 7, 2023 / 110 tlb deere overheat #2 Peter 315 Super Member Joined Mar 28, 2016 Messages 5,189 Location NH Tractor Kubota L3800 HST Kubota L47 TLB No I have not, but the hyd oil cooler should not cause it to over heat . Are you using a 50/50 mix of antifreeze?
Sep 8, 2023 / 110 tlb deere overheat #3 B beenthere Super Star Member Joined Aug 16, 2001 Messages 18,687 Location Southern Wisconsin, USA Tractor JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold) If the oil cooler is plugged up, then it could cause overheating as the pass-through air cannot also pass through the radiator. Do you have an infrared surface thermometer?
Sep 8, 2023 / 110 tlb deere overheat #4 5030 Rest in Peace Joined Feb 21, 2003 Messages 28,967 Location SE Michigan in the middle of nowhere Tractor Kubota M9000 HDCC3 M9000 HDC Ever bother cleaning the rad or the heat exchanger? bet not.
