$11,000 Water Bill
   / $11,000 Water Bill
I appreciate all of the advice and support. I've been reviewing all of the comments and making calls to gain information. I will say that the NC Plumbing Commission doesn't seem like they mess around. They prosecute contractors that do plumbing work without a license - if they have contractor licenses they will persue that license. We still don't have any resolution, but I have MULTIPLE avenues available to persue. I am amazed by the NC state regulatory commissions. They don't play games.
   / $11,000 Water Bill #144
I thought about PEX, but it seems like it's pretty hard to come by in 2". Also - fittings of that size seem difficult to find. Is this something that's available through a plumbing supply store?
I'm in a similar but nowhere near as costly situation in my house in Mississippi which is about 400 feet from the main. Water leak after the main, about 30 gallons of leak per hour. I've a 300 gallon IBC tote and run a bucket brigade for toilet flushing etc. Fill the tote up about once a week, do laundry, don't bathe often.
We are supposed to get the line replaced this summer and were advised to use "black poly" and I looked into PEX. Seems PEX is better NOT buried. High pressure (160+) black poly is what is used in my area.
   / $11,000 Water Bill #145
I'm curious, if this issue were in your state, do you see the GC as being responsible for the 11k water bill, and do you see it as being a "easy" case to collect?
Given the facts as presented it seems to me the house is under warranty so GC is on the hook. GC also, apparently, used unlicensed contractors to do the work that is now faulty. Even if licensed the GC picked them so the GC bears the responsibility.
That said immediate filing of a law suit is not the best resolution.
Ideally OP would get a trusted plumbing contractor out to look the work over and give an honest opinion as to the issues and what went wrong. Then a letter from a lawyer saying here is what is wrong please fix and pay the $11K water bill.
As far as collections, I have no way to formulate an opinion on the matter. I know nothing about the GC's finances.
I'd take the case because it sounds like OP got the shaft. He is serving overseas. His wife is serving here and taking care of their minor child by herself while he is deployed. So I'd take it more out of a sense of patriotism than making any money off the deal. So I guess it is a good thing I do not live near a military base or my practice would be nothing but cases like this.
Ultimately I do not think lawyering up is the wrong thing to do. Filing a law suit may well be the wrong thing to do.
Since his wife has access to a JAG officer for advice she should at a minimum talk to that lawyer.
   / $11,000 Water Bill #146
Justinramani - since a significant amount of time is passing, how is your wife handling not having water?
While my in-law's cabin was under construction, and for almost a year afterward before their permanent water line was run, we ran a "temporary" water line through the woods from our construction site to theirs using 400 ft of off-the-shelf but high quality garden hose from Sam's. It was NOT super high flow, but adequate to flush a toilet and take a shower. Made up adapters at each end for connections. Reasonable cost and usable later. I installed a pressure regulator at the source end to keep it down to about 40psi on the hose. I expected occasional leaks from critters chewing it, but never had a problem.
   / $11,000 Water Bill #147
OK - I am real curious. Eddie and another poster from Texas have heard of problems with black poly pipe but I and so many others have had great experience with it. What is different about the ground in Texas that black poly pipe doesn't work there?
I cannot imagine using rigid PVC buried and not having flexible joints such as the ones the city used in the rock. That stuff is brittle and will not take the ground flexing as it does. Somebody mentioned putting it in 4" corrugated which I can see because then you protect it from the ground movement but that is a lot of work. Underground the temperature does not change as much as above ground so thermal growth and contraction should not be an issue.
   / $11,000 Water Bill #148
Justin - It sounds like you go the builder's attention. If you work with the water department and hopefully get the bill reduced and also "help" the builder to get his costs reduced if he works quickly. Find the honey - it almost always works better than threats - of course sweetly include the assumption that is his bill and you are just trying to help.
   / $11,000 Water Bill #149
The builder may have a significant amount of pull with the water department, especially if he is putting in a couple of subdivisions...
Aaron Z
   / $11,000 Water Bill #150
I don't have black poly. I went with gasketed pipe for my place based on what I could learn about the various types of pipes out there and the recommendation from my water district. My run is 800 feet. I make a living fixing houses and remodeling them. I would guess that I'm exposed to more houses them most people, and I see what fails more often then most. I'm not a plumber and I'm not an expert in anything.
Black Poly is one of those products that fails more often then anything else out there. I checked code in one place because another posted said that's all they use there, like so many others do, and I could not find poly being code in that state. It's probably fine for short runs, and some soils. But just like those people who say they smoked cigarettes all their life and didn't get cancer, the risk is still there and too high for me to take a chance.
Why use a product that isn't the very best? Pipe with gaskets in it is the best choice available today for long runs.
I also wonder if those people suggesting using poly pipe realize this is a 1,300 foot run?
$11,000 after using the wrong product once sure makes me hope that going cheap on the wrong type of pipe a second time doesn't result in this happening again.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
CASE IH 2412 - 12R CORN HEAD (A51243)
CASE IH 2412 - 12R...
2005 Wilson Hopper Bottom Trailer (A50514)
2005 Wilson Hopper...
J & M 30' Head Cart (A50514)
J & M 30' Head...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
28013 (A50322)
28013 (A50322)
