$11,000 Water Bill
   / $11,000 Water Bill #31
Well - its pure sand. Water leaches away pretty quickly. The pipe is about 2 feet deep or so. We have had multiple repairs on the line in the last year. We still have a few weeks left on the warranty. I have told the builder that I want the line replaced. He has not yet responded. I just can't imagine that that hole in the pipe was naturally created. The water dept is working with us a little, but the bill will still be in the thousands.....
OK, now were are getting somewhere. Did the other leaking pipes/damage to the pipes look like this one?
   / $11,000 Water Bill #32
I see purple primer and maybe some clear glue on that joint. Properly done it should have held.
Were a number of the other leaks at joints?
The pipe is 2inch and the meter Is 1.5. The county is convinced that the reading is accurate.
Yes, I know that at least two other leaks occurred at joints. I don't think those leaks were nearly as big.
It's hard for me to believe that a hole that size @ 60 psi could flow at a rate of 50 gpm. It just doesn't seem plausible.
   / $11,000 Water Bill #36
Two other leaks...good grief! Thank goodness they were small leaks! It sure seems like it is a glue problem.
What do y'all think about the replacement line. I'm going to have it replaced. The options are 200 psi HDPE in 500 foot sections or PVC again. The pvc would have over 50 connections. The black pipe would have three.
   / $11,000 Water Bill #38
x2, i generally just call it black poly pipe/hose. less connections, and the hose goes with the trench it is put in, if the hose is put in correctly. snaked / weaved / wave pattern (side to side) within the trench. it can move back and forth up and down some without putting extra stress on anything.
sch40 or like pvc hard pipe. does not really give. and any slight angles tends to put stress on at the joints. or not fully seated joints.
sch40 pvc and like joints, can be rather troublesome, if not pressure tested, before being burried, and inspected. even after being buried. if the pipes were not properly chemical welded (most folks call it glued), the pipes can still come apart.
if the trench is not properly back filled with clean soil (no rocks and other junk in it) along with compacting the trench as it is back filled. the pipe can end up cracking/breaking more easily. as everything settles over time, resulting in empty voids under sections of the pipe.
check local city/township/county building office. they should have records for inspections.
with others get another plumber out there, and get a bid to repair. before it is actually repaired. so you have something else for documentation if it goes ugly. keep orginals and only give out copies to others if need be.
small claims = small claims court. no lawyers allowed in court room, atleast here it is, if it goes that far. see what max amount can be asked for. to see if small claims court is possible.
get your documentation, pictures around.
when taking to small claims, make sure you get the builder, plumber, and anyone else involved. on same suit. so they can not pass the buck to someone else, saying it was this or that person or company fault.
   / $11,000 Water Bill #39
Up north here they use the flexible black plastic pipe that comes in a large coil. It's buried in all kinds of soil in a bed of sand. I don't know what they call it, but I'd never use the rigid plastic pipe for anything but drain. Indoor plumbing has gone from copper to PEX also. Home runs, no joints and tough.
   / $11,000 Water Bill #40
The run is about 1300 feet with a good elevation change (valley) in the middle. They used schedule 40. Attached is a picture of the pipe. I know that after the pressure reducing valve the pressure is around 60-70 psi. View attachment 509302
The pic in this post show's the pipe is "DWV". I'm not a licensed plumber but as far as I know the "DWV" means Drain-Waste-Vent, only!
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
