1086 digital data center help
/ 1086 digital data center help #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
The digital data center on my International 1086 keeps going nuts. It will work for a while, then the numbers jump around, and the display is bright on the first digit, and the rest are real faint. I know from sound about where the 540 pto is, but having the read out is better. Also jumps around on the exhaust gas. It is a digital read out with pto 540, pto 1000, rpm, speed, exhaust gas, and I think one other. It is the type you push on a flat surface to change between the different readings. That does not always work either.
Can this be fixed and who can do it. I called a local International dealer and he said new one is $1200, ahhh.
Can anyone help please?
Thanks.
/ 1086 digital data center help #2
Slippy...I saw your post here for that 1086 digital data deal some time ago, and asked today while on the phone with 2 pretty extensive tractor junkyards I've used, 1 in VA and the other in NC, and neither one had ever had a large IH that recent come in. Just thought I'd mention it, though I reckin' it isn't any help. Hope you get that working for less than it is looking like.
I found a place that will repare for $150. Thanks taking the time and checking. That was very kind of you.
/ 1086 digital data center help #4
You do seem to have some internal problems with the unit but the one thing that helped many was being sure the grounds are good.
