1026r curl function backflow
/ 1026r curl function backflow #1
swick1
Platinum Member
WV
John Deere 1026R
When I have to curl with my pallet forks on unless I move the valve all the way open very fast I get backflow through the circuit and the forks drop a couple of inches before curling back properly. Is there an easy fix to this problem? It makes bulky items scary to lift.
Where would this valve be located? Before the valve block?
/ 1026r curl function backflow #4
I think this is a known issue with the 1-series -- talk to your dealer about it. There is a fix they can apply.
/ 1026r curl function backflow #5
I had the same problem. The dealer replaced the SCV and everything worked properly after that.
Thanks. I'll visit them tomorrow and let you know what they say!
/ 1026r curl function backflow #7
The load check valve is usually in between the work ports.
Remove and inspect, clean, or replace.
They say the dropping is normal and all the 2000psi tractors do it
/ 1026r curl function backflow #9
Don't buy that -- they are selling you a line of BS. It should not do that.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
Caterpillar Service Letters 1960's and 1970's (A63117)
Caterpillar...
JMR TREE BOOM (A61572)
2016 Nissan NV2500 Cargo Van (A61573)
2016 Nissan NV2500...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
