1026r block heater location?
   / 1026r block heater location? #1
OrangeJbird
NW WI
3320 w/300cx FEL
Does it go in a threaded plug hole? Size? Which side and where on engine? Does Kats or any other aftermarket have them? Not going to pay dealer JD price or $400.00 for them to install.
Thanks for looking.
   / 1026r block heater location? #2
I replaced my block heater on my jd2320 last year. I found out the JD part # was exactly the same as an after market one. If you pm me tomorrow I get the part for you.
   / 1026r block heater location? #3
I just checked the JD part number you need is AR8716. Yes it is the same as the part number as my 2320. The Zerostart brand part # is 310003. The are excatly the same. Very simple install. You'll find a plug mounted in a flange on the right(passenger) side of the tractor right near the fuel filter. Remove the friction fit freeze plug. Than threading the heater, dont forget the teflon tape, and voila your done. The worst part is dealing with the anitfreeze.
$ 80.55 at John Deere Model 1026R Compact Utility Tractor Parts
OR
check autozone or your auto parts store of choice.
AR87167 Deere and 310-0003 ZeroStart are the same item at greatly different prices!
I appreciate the info.
Thanks!
   / 1026r block heater location? #6
Also need AM134805 adapter kit for the 1026r block heater.
   / 1026r block heater location? #8
I think I used a hook style seal pulling tool. A slot screw driver and hammer will work also. It pretty thin material. Puncture it closer to one side than pry it out. Not as harder as it looks.
   / 1026r block heater location? #9
Thank you!
Schuler 125BF Feed Wagon (A59814)
Schuler 125BF Feed...
large capacity skid steer bucket (A56857)
large capacity...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
Honda UTV (A56859)
Honda UTV (A56859)
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
