1025R Rear Tire Bead
   / 1025R Rear Tire Bead #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I was working in the woods yesterday and saw fluid coming from one of my rear R4’s. After removing it I noticed a few small pieces of wood had wedged themselves between the tire and the rim unseating the tire - maybe one inch of circumference. I dug out the pieces… should the bead be okay or is it likely I’ll have to remove/reinstall the tire?
   / 1025R Rear Tire Bead #2
You'll know if it leaks. If it leaks, I'd take it off and deflate the tire. Do your best to open up the bead where the wood was. Get some bead sealer and put that in there and reinflate. Should be good.
   / 1025R Rear Tire Bead #3
If you have filled rear tires I’d just keep an eye on it. What kind of fluid is in there?
   / 1025R Rear Tire Bead #5
Could be Rim Guard, a sticky beet juice derivative or methanol, which is usually windshield washer fluid. You probably don’t want to mess with it to much or you’ll lose the fluid.
   / 1025R Rear Tire Bead #6
Lay the tire down flat, with questionable bead topside. Then break the bead, clean out any debris, and re-inflate. Won't lose any fluid that way.
It is the way I originally filled my rear tires with windshield washer fluid.
Great advice! Thank you to all who posted.
2025 Safety Basket Forklift Attachment (A49346)
2025 Safety Basket...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2013 FREIGHTLINER CASCADIA SLEEPER (A50505)
2013 FREIGHTLINER...
2014 Peterbilt 320 Altec AH150 Boom Truck (A49461)
2014 Peterbilt 320...
