1025R Rear Tire Bead
   / 1025R Rear Tire Bead #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I was working in the woods yesterday and saw fluid coming from one of my rear R4’s. After removing it I noticed a few small pieces of wood had wedged themselves between the tire and the rim unseating the tire - maybe one inch of circumference. I dug out the pieces… should the bead be okay or is it likely I’ll have to remove/reinstall the tire?
   / 1025R Rear Tire Bead #2
You'll know if it leaks. If it leaks, I'd take it off and deflate the tire. Do your best to open up the bead where the wood was. Get some bead sealer and put that in there and reinflate. Should be good.
   / 1025R Rear Tire Bead #3
If you have filled rear tires I’d just keep an eye on it. What kind of fluid is in there?
   / 1025R Rear Tire Bead #5
Could be Rim Guard, a sticky beet juice derivative or methanol, which is usually windshield washer fluid. You probably don’t want to mess with it to much or you’ll lose the fluid.
   / 1025R Rear Tire Bead #6
Lay the tire down flat, with questionable bead topside. Then break the bead, clean out any debris, and re-inflate. Won't lose any fluid that way.
It is the way I originally filled my rear tires with windshield washer fluid.
Great advice! Thank you to all who posted.
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
Rooster Wooden Statue (A55853)
Rooster Wooden...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
2011 John Deere Tractor (A55973)
2011 John Deere...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
