1025R Front End Loader not going up all the way?
   / 1025R Front End Loader not going up all the way? #1
finishman2000
It seems that my 1025r FEL just isn;t going up as high as it used too. It goes up quickly and smoothly right to the end point but seems about a foot less that last year. They say 72" but at what point is that taken? Thanks
   / 1025R Front End Loader not going up all the way? #2
Check the hydraulic fluid level, it may be low.
   / 1025R Front End Loader not going up all the way? #3
You might disconnect and reconnect the loader hoses.
   / 1025R Front End Loader not going up all the way? #4
Be sure your hydraulic fluid isn't low. I think the loader height is measured from the bottom of the bucket but could be mistaken. The manual may give dimensions and measuring points.
I thought the level was good. I wish there was a dip stick to check it.
   / 1025R Front End Loader not going up all the way? #6
I would have thought it wood have been measured to the pins but don’t know for sure.
   / 1025R Front End Loader not going up all the way? #7
JD went to a lot of trouble to manufacture and install a dipstick in the rear of the transmission housing of the 1025R. Why can't you use the dipstick they supplied?
1000 GALLON PROPANE TANK (A52708)
1000 GALLON...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A56857)
2024 AGT LRT23...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
9ft Reading Utility Bed Topper (A57453)
9ft Reading...
22 BLADE DISC HARROW, 3PT (A58374)
22 BLADE DISC...
2 EYE GAS BURNER (A58374)
2 EYE GAS BURNER...
