1025R Front End Loader not going up all the way?
   / 1025R Front End Loader not going up all the way? #1
finishman2000
It seems that my 1025r FEL just isn;t going up as high as it used too. It goes up quickly and smoothly right to the end point but seems about a foot less that last year. They say 72" but at what point is that taken? Thanks
   / 1025R Front End Loader not going up all the way? #2
Check the hydraulic fluid level, it may be low.
   / 1025R Front End Loader not going up all the way? #3
You might disconnect and reconnect the loader hoses.
   / 1025R Front End Loader not going up all the way? #4
Be sure your hydraulic fluid isn't low. I think the loader height is measured from the bottom of the bucket but could be mistaken. The manual may give dimensions and measuring points.
I thought the level was good. I wish there was a dip stick to check it.
   / 1025R Front End Loader not going up all the way? #6
I would have thought it wood have been measured to the pins but don’t know for sure.
   / 1025R Front End Loader not going up all the way? #7
JD went to a lot of trouble to manufacture and install a dipstick in the rear of the transmission housing of the 1025R. Why can't you use the dipstick they supplied?
8 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
8 Piece Mini...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
LANDHONOR LHR-RM90 VIBRATORY JUMPING JACK (A52708)
LANDHONOR LHR-RM90...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
