1025 kept slowing down
   / 1025 kept slowing down #11
Mostly off your subject.
Sorry to hear you are having trouble with a new JD 1025.
My JD dealer is telling me my 1025R will break shear pins at startup on a 4' Brush Hog and I should buy a JD with a slip clutch. What is your experience?
Haven't broken a shear pin yet on my Frontier bush hog; only have spare bolts from the old JD bush hog, hoping they'll work on this one. The hydraulics on the 1025R apparently have something built in for a smooth startup. Not much chance in popping a shear pin on startup. On the 4010 that I had, yes. That thing would slam the PTO on. I often had to restart it 2 and 3 times to get the bush hog blades swinging properly. One time, I even had to stop it and get underneath with a pry bar to get the blades apart. They'd locked up on each other with the abrupt startup.
I fixed the throttle myself today. Just didn't want to go through waiting for the service man again, etc. I looked at it, and nothing appeared broken. There is a BIG washer behind the 2 lock nuts. I just got a 17 mm socket and put a universal on it and a very long extension to reach through from the back side (left side panel off). The nuts were very loose. If this happens in the future again, I'm gonna put a glob of Goop (heavy silicon) on the end of the nut and on the shaft to see if that will stop the nuts from working loose.
Ralph
   / 1025 kept slowing down #13
Maybe try a nyloc for the end nut?
Nick
   / 1025 kept slowing down #14
By lock nuts do you mean jam nuts? Maybe the service guy did not get them tight so they vibrated loose.
VERY difficult to get in there at the 2nd nut. You can mainly only get a wrench on the end nut and tighten up.
Would require a very special 17mm wrench to get it in there on the other nut, the one up against the washer.
Ralph
   / 1025 kept slowing down #16
Nyloc nuts are self locking. They have a nylon bushing crimped on the end which keeps them from loosening off. You don't need to double nut a bolt with ny-loc nuts although if properly installed, I have never had a double nut loosen off.
   / 1025 kept slowing down #17
Ralph
A trick I have used in the past when a "Specialty Wrench" was needed, was purchase a moderately priced wrench at Northern Tools, and heat and bend the wrench into the configuration needed. You may also be able to reach into the area with a "Crows Foot Line Socket" or a "Starter Wrench". Here is a Google page of specialty wrenches. https://www.google.com/?gws_rd=ssl#q=speciality+offset+wrenches
   / 1025 kept slowing down #18
I run a 4' Howse rotary cutter on my 1025r and have not had a problem with shear pins breaking. Engage the PTO at low RPMs (I usually engage at just over idle) then slowly rev up to PTO RPM. I haven't had any such problem at all...
   / 1025 kept slowing down #19
I had a similar problem on my 1026R. I had to have the friction disc on my throttle lever replaced because it wore out.
Is the friction disc behind that big washer that's immediately behind the lock nuts?
So far, mine's holding now after I retightened it myself.
Ralph
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
JOHN DEERE 6000 SERIES BRUSHGUARD (A58375)
JOHN DEERE 6000...
UNUSED FUTURE 25MM MINI EXCAVATOR ATTACHMENT SET (A58376)
UNUSED FUTURE 25MM...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
2007 Freightliner (A57148)
2007 Freightliner...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
