1020 Wheel lock up?
/ 1020 Wheel lock up? #1
Rob52
Bronze Member
Mid Mich
2005 John Deere 4320
Had an incident where the left wheel locked up and would only proceed with diff. lock engaged. About a year prior, my dad was using loader and right side locked up, but I had noticed the PTO had been accidently kicked up partially engaged, moved back to off, no problem. The recent incident alarmed me and I have completely tore down rear end, removed both outdrives, rockshaft housing and removed pinion gear. Everything seems to be fine, nothing excessively worn, only thing I found was a brake liner was out of round with a crack in it on right brake? Any ideas?
Loader was added last year by myself, tractor was completely overhauled 3 years ago, engine, paint, many new JD parts, tires. I replaced load control pin and bushings last year due to a bad leak and replaced alot of leaking hose clamps, dry ever since!
