1014 Front End Loader Spec on a 1020
   / 1014 Front End Loader Spec on a 1020 #1
AllWaysBreakinSomething
Cherryville, NC
MF165, Ford Workmaster 661, Super A, Bobcat 943
I'm curious as I have a MF1020 with a 1014 FEL with a 5 ft bucket. I question if the loader is working correctly as I'm not able to lift a full bucket for some types of materials... How much weight should I be able to lift with this loader from the ground? Anyone have any specs on this loader? I don't have a manual for it.
   / 1014 Front End Loader Spec on a 1020 #2
I don,t now the spec on your fel . but my 1020 has an alied 180 fel and I have to be carful because I can lift the back tires off the ground when scooping.
Hmm!! I can't do that. I can lift the front tires though.
   / 1014 Front End Loader Spec on a 1020 #4
The published lift spec is 500 lbs. I have the same setup, and I know it will do more than that though.
   / 1014 Front End Loader Spec on a 1020 #5
Hi Unless it is Lead You should be able to pick up a full bucket of any Material this would be a water level full
The problem that may bve going on is the releif valve needs to be adjusted it is located in the spool valve I will check it out and get back to you on it
   / 1014 Front End Loader Spec on a 1020 #6
I'm looking for a M-F 1014 loader...have not been able to locate one. Mike
   / 1014 Front End Loader Spec on a 1020 #7
I'm looking to buy a M-F 1014 loader. Is there anyone out there that can point me in the right direction???? mikewav@bright.net(winomike)
PORTABLE UP RIGHT FUEL TANK (A51248)
PORTABLE UP RIGHT...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
UNUSED RAYTREE REDM32-32" EXCAVATOR DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
