1014 Front End Loader Spec on a 1020
   / 1014 Front End Loader Spec on a 1020 #1
AllWaysBreakinSomething
Cherryville, NC
MF165, Ford Workmaster 661, Super A, Bobcat 943
I'm curious as I have a MF1020 with a 1014 FEL with a 5 ft bucket. I question if the loader is working correctly as I'm not able to lift a full bucket for some types of materials... How much weight should I be able to lift with this loader from the ground? Anyone have any specs on this loader? I don't have a manual for it.
   / 1014 Front End Loader Spec on a 1020 #2
I don,t now the spec on your fel . but my 1020 has an alied 180 fel and I have to be carful because I can lift the back tires off the ground when scooping.
Hmm!! I can't do that. I can lift the front tires though.
   / 1014 Front End Loader Spec on a 1020 #4
The published lift spec is 500 lbs. I have the same setup, and I know it will do more than that though.
   / 1014 Front End Loader Spec on a 1020 #5
Hi Unless it is Lead You should be able to pick up a full bucket of any Material this would be a water level full
The problem that may bve going on is the releif valve needs to be adjusted it is located in the spool valve I will check it out and get back to you on it
   / 1014 Front End Loader Spec on a 1020 #6
I'm looking for a M-F 1014 loader...have not been able to locate one. Mike
   / 1014 Front End Loader Spec on a 1020 #7
I'm looking to buy a M-F 1014 loader. Is there anyone out there that can point me in the right direction???? mikewav@bright.net(winomike)
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
2015 DODGE RAM 4500 HD SERVICE TRUC (A51247)
2015 DODGE RAM...
PALLET OF 6' X 12' SITE FENCE (A51248)
PALLET OF 6' X 12'...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
UNUSED CFG...
