100 hr Service
/ 100 hr Service #1
Jw5875
NW Pa.
Kubota L3400
I just did my 100 hr. service on my L3400 gear drive. Air filter was sure dirty, but my real surprise was how much the fan belt had stretched --- Wow!!!! I could turn the alternator pulley by hand before I made adjustment.
Kubota manual state's to only change the oil at 100 hrs. I changed the filter as well.
JW 5875!
/ 100 hr Service #2
Jw5875 said:
I just did my 100 hr. service on my L3400 gear drive. Air filter was sure dirty, but my real surprise was how much the fan belt had stretched --- Wow!!!! I could turn the alternator pulley by hand before I made adjustment....
In general, rubber parts age with calendar hours/months/years not "use hours". What year is your L3400?
Talon Dancer
/ 100 hr Service #3
JW 5875:
Just wondering what all you did, and how long it took you. I took my NH to the dealer for the 100 hr mtse and it cost me almost $400.00. I was expecting $100 to $150. Boy was I surprised.
/ 100 hr Service
Talondancer,
2005, 1st yr. only had 17 hr's on machine. 2nd Yr., made 50 hr. mark for for Kubota required maintenance.
Bizdoc,
NH? different deal, i.e : different labor hrs / cost of oil / filters etc.
plus cost of pick-up and deliv. for machine.
My total time to do the Kubota service check, 3 Hr.s + - (Beer's)
JW 5875!
/ 100 hr Service #5
Jw5875 said:
...2005, 1st yr. only had 17 hr's on machine. 2nd Yr., made 50 hr. mark for Kubota required maintenance....
My L3240 manual suggests _replacing_ a whole slew of rubber parts EVERY two years _regardless_ of usage hours ( e.g. radiator hoses, power steering oil lines, fuel lines, HST oil line, lift cylinder hose line, etc.).
I noticed that many folks posting on this forum have very low usage/yr. I'm sure its tempting to say "hey, I hardly use that tractor. its almost brand new". But these parts don't wear out due to usage. They wear out due to calendar age. And BTW they usually fail catastrophically :(
FWIW I have a couple a very, very low milage vintage cars and the parts that fail are almost invariably _rubber_ ( e.g. belts, hoses, fuel lines, etc.).
Talon Dancer
/ 100 hr Service #6
:eek: I don'tknow if I was supposed to change these, but there are rubber connections on the NH about 3 or 4 inches long that connect the stiff lines for the hydrolics just under the tractor. I didn't even know they were there, but at 400 hours one of them blew while I was mowing and I now have a nice big oval brown strip in my yard where the hydrolic fluid gushed out. that's one way to have the fluid changed. That was annother $150.00 to have these connectors replaced.
5103SFL (A64553)
5103SFL (A64553)
2015 ARMOR LITE TRAILER (A67714)
2015 ARMOR LITE...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
