Grading $100.00 snow blade attachment
   / $100.00 snow blade attachment #1
TOMLESCOEQUIP
Platinum Member
Strasburg, OH
Attached is a picture of the snow blade attachment I made for my NH skidsteer..........I started with a $50 myers plow I found behind the storage lot at a local towing facility. Bought $30 worth of 1/2" plate and bar stock and fabbed up a plate to fit the quick tach bracket on my ss loader. I cut 12" off each end of the blade due to the small size of my skidsteer leaving just over 5' of width.....I cut the A frame bracket on the plow shorter and added vertical reinforcements to each side of the shortened A frame..........I use the plow with the loader valve in the float position...........If you built a similiar attachment for a FEL you could use the original snow plow lift chain setup attached to the quicktach (at the top of the bracket ) and use the curl valve (bucket control) to raise/lower the blade.... All in all an inexpensive solution to the snow removal problem
Close up of mounting bracket
3rd view
   / $100.00 snow blade attachment #4
Certainly looks like that should move some snow.
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
2003 Nissan Xterra SUV (A55853)
2003 Nissan Xterra...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A57024)
2018 John Deere...
