Grading $100.00 snow blade attachment
   / $100.00 snow blade attachment #1
TOMLESCOEQUIP
Platinum Member
Strasburg, OH
Attached is a picture of the snow blade attachment I made for my NH skidsteer..........I started with a $50 myers plow I found behind the storage lot at a local towing facility. Bought $30 worth of 1/2" plate and bar stock and fabbed up a plate to fit the quick tach bracket on my ss loader. I cut 12" off each end of the blade due to the small size of my skidsteer leaving just over 5' of width.....I cut the A frame bracket on the plow shorter and added vertical reinforcements to each side of the shortened A frame..........I use the plow with the loader valve in the float position...........If you built a similiar attachment for a FEL you could use the original snow plow lift chain setup attached to the quicktach (at the top of the bracket ) and use the curl valve (bucket control) to raise/lower the blade.... All in all an inexpensive solution to the snow removal problem
Close up of mounting bracket
3rd view
   / $100.00 snow blade attachment #4
Certainly looks like that should move some snow.
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
KIDS DIRT BIKE (A53424)
KIDS DIRT BIKE...
1996 Sunflower 1543-38 Folding Disk (A57024)
1996 Sunflower...
UNUSED FUTURE MINI QUICK COUPLER (A57193)
UNUSED FUTURE MINI...
2020 FORD F250 XL EXT CAB TRUCK (A57192)
2020 FORD F250 XL...
John Deere 5100M (A53317)
John Deere 5100M...
