10 Gallon Sandblaster
/ 10 Gallon Sandblaster #1
jgbanshee
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
I have a 10 gallon tank sandblaster that DOES NOT work. It has the ridiculous little valve for a gun. Is there something that I might be doing wrong. It blasts for one second and stops. The tip is not clogged. I have a 26 gallon air compressor at the other end. Anyone know of a good but fairly low priced sandblaster or even a cabinet out there?
/ 10 Gallon Sandblaster #2
I bought an attachment for my pressure washer to sand blast. Now it's not for every sand blasting job but it sure works slick. The water keeps the sand from floating in the air and with 1,800 psi it'll move some rust and paint fast. If you have a pressure washer you might want to check them out.
I had to replace the floor in my cattle trailer. Talk about major rust. I caught it in time too. Got it sealed up now. I ran 1,000 pounds of sand through it on that job. Once folks found out I had one the women in the area bring all their rusty cast iron pots and such. /forums/images/graemlins/cool.gif It's a good way to meet women. /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif Joking aside, it does some pretty work. Just have to get it dry fast and prime it.
Just thought I'd throw that idea up here. Have a good one.
/ 10 Gallon Sandblaster #4
Is your blaster a siphon feed or pressure feed??
If it is a siphon feed (cheaper model), the abrasive has to be DRY. I mean really dry. If not, it will not feed. The gun needs a small hole to accelerate the media. If the media is at all damp, it won't work.
If you have a siphon feed, dump it and get a pressure blaster. Much less fussy, though more expensive.
It is a pressure feed sand blaster.
/ 10 Gallon Sandblaster #6
Don't now if this will help or not but once in awhile when mine stops, I blow air from the nozzle back to the tank (reverse flow). This will clear any restrictions from damp sand or moisture build up in the system - Lewis
/ 10 Gallon Sandblaster #9
I bought this one because it's made for the pressure washer I have. Easy connection. Push and twist. Wet Sandblasting It says in the add it's for all ele. models but it works on my Gas model too. Same hookup.
Northern tools sell one for larger pressure washers. I think it'll move 700 pounds per hour at 3,000 psi.
/ 10 Gallon Sandblaster #10
You probaly have the little valve most blasters come with. You need a larger type deadman valve. They sell them in a nearby import store called Wood Sales. I know of a few folks that make theyre own blasters out of a refrigerant tank and the 10 dollar deadman kit.
/ 10 Gallon Sandblaster #11
I bought a pressure blaster a while ago and could not get it to work either.
It would do similar to what you describe, work a short while then quit.
I notice several others have said you may have wet (damp) sand, well mine was so dry that it would run out of the bottom of the tank without any pressure, like an hour glass does. The spec sheet that came with it showed one more valve than was in the package. I called the seller and after a discussion, was given permission to return it for a full refund. I would still like to have a pressure blaster that would work but am still pluggin along with siphion feed. I realize this is no help solving your problem.
Hope you find the answer to make it work.
/ 10 Gallon Sandblaster #12
Can you tell us where these units came from?
Fred
/ 10 Gallon Sandblaster #13
Sorry 'bout the delayed answer.
I purchased from one of those "truckload stay in town a couple of days" outfits.
Sorry I don't remember which one. Wish I did because they paid frt to return and gave full credit return.
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
New/Unused Wolverine 78in Quick Attach Rock Bucket (A65583)
New/Unused...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
