10 Acres of Brush
   / 10 Acres of Brush #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
Please excuse this first post. I have lurked for a few months, getting somewhat closer to making a few decisions with GREAT help from info on this board. Thanks alot.
We bought 10 beautiful acres in the central coast of California, and know (next to) nothing about various aspects of land management. City slickers.
My question has to do with brush that covers most of the 10 acres.
When we purchased the land in November, the whole property had what looked like close-cropped, almost mowed, 'grass'. It was dead and brown in most places. Now there are weeds about 3' or 4' high on most of the property. We don't know if it needs to be mowed, turned under, left alone, or some other alternative.
If we leave it alone, it seems like the tall weeds would eventually break down when they die and create some sort of havoc - but we don't know that to be the case. And we don't otherwise think the weeds have to be cut down if it isn't necessary.
So now the questions: do we need to tend to this brush in any way from the perspective of land management, and if so, how is it done and what tools should we use? A tractor is in the horizon relatively soon.
The land is hilly with flat areas too. I'd say that 25% is pretty flat, and the rest is hilly. Not too steep. I'm sure that a tractor would be able to navigate safely on the slopes. There are some trees on the property. But again, it is mostly field and many different types of tractors can probably get around/under the trees.
One other thing is that I have some houses on the property that also need mowing. In these areas there are more trees and the brush is more lawn-like. I'm thinking that these areas will need to be 'mowed' using different tools than what might be needed for the rest of the property - but of course it would be nice if I could use the same equipment.
Thanks for your help.
Martin Petersen
   / 10 Acres of Brush #3
Martin...First off, that land looks pretty nice !!!
Now simple progression....grasses become woody weeds...woody weeds become small brush....small brush becomes trees or a wildfire !!
Looks like you'd have your hands full trying to mow that area and keep it tame. Any animals on the horizon ??? They can do a nice job of hill-mowin'.
   / 10 Acres of Brush #4
Looks like a very fine place to call home.
Welcome to the TBN forums. Lots of great experience here - but you already know that.
Bob
   / 10 Acres of Brush #5
Hello Martin--Welcome to TBN--Really nice property--How about hiring a custom operator to come in and Brush Hog the larger grasses before they get out of control or rent a similar outfit for a weekend--You should be able to maintain the yards with conventional lawn mowing equip. until the tractor comes into play, later on??--Ken Sweet
Sweet Farm Equipment Co.
   / 10 Acres of Brush #6
</font><font color="blue" class="small">( A tractor is in the horizon relatively soon. )</font>
In view of the fact that you expect to buy a tractor, I think I'd go ahead and get one. It's hard to say just what to get without knowing just what you intend to do on that property, but I'd be looking for a tractor in the 30hp (+/-), 4WD, hydrostatic transmission, front end loader, and a rotary cutter (brush hog) just a little wider than the outside of the rear tractor wheels And it sounds like you're also going to want a finish mower in the near future, too. Looks like a pretty place.
   / 10 Acres of Brush
Thanks for the notes.
Well, right now we have 8-10 projects that call for a tractor. But some of those projects are clean-up of the site, which will be 1 time purposes only. We are pulling down old structures, fixing some serious drainage problems, pulling out poles and posts that are long abandoned, moving dirt here and there, filling in an old lap pool, etc. So far, without anything but hand tools at all, we have removed 12 tons of debris off the property.
These are obvious 1-time projects that I can probably rent a tractor for as needed.
I'm still trying to learn what ONGOING maintenance-type of projects will be. Brush control seems to be one of them. We have a gravel driveway which seems to be another. We plan for an orchard - tilling or whatever that takes, as another. Ongoing chipping and schredding. Probably more dirt-moving now and then. Nothing obvious now relative to ditch-digging. Maybe a few projects for installing poles/posts. Etc.
I'd like to watch this board a little longer, make a list of what I think the ongoing projects will be, and then post again at that time. The community here just seems fantastic - when others have done similar to me, the recommendations appear to be right on.
One question though - is it bad for the land to simply leave those bushes uncut? Is there some natural process we would miss by leaving them uncut - excluding the appearance factors, that is?
Thanks again.
Martin Petersen
   / 10 Acres of Brush #8
Martin, your not considering the most important factor in tractor ownership...the FUN. You know...boys and their toys !!
I don't see any negative impact on the land by letting it grow short of the increased difficulty dealing with the space in the future. Grass is easy to mow...trees and scrub become a different matter.
Are you far enough north to be out of the regular wildfire area ??
   / 10 Acres of Brush #9
That is a beautiful place. Is that a whitetail under the tree?
<font color="blue"> One question though - is it bad for the land to simply leave those bushes uncut? </font>
You can tell what the land will look like uncut by looking at other land in the area that is never cut or grazed. Then you can determine if that is the look you want.
You can maintain the pastures by mowing only 3 or 4 times a year or less if all you want to do is keep it from growing up in brush. Tall weeds (even 3' - 4') are not difficult to mow with a decent size tractor (~25-35hp) and rotary cutter.
   / 10 Acres of Brush #10
SLOBuds
Nice looking property! I am in the Gilroy area with 5 acres, looked in the area you are in. Make sure you stay on top fo the weed control because of the fire danger (in most of Calif). Were you living in the area during the Hwy41 fire? Find your local Fire Prevention Officer and talk to them.
   / 10 Acres of Brush #11
</font><font color="blue" class="small">( is it bad for the land to simply leave those bushes uncut? )</font>
In my opinion, No. As far as I know, the only negatives are appearance and possible fire hazard. And of course, if brush grows to trees, you might need an even heavier duty mower when you do decide to mow. On the other hand, a possible positive might be that it could be better habitat for things like birds, rabbits, etc. if you do leave it uncut. Just depends on what you want, both now and in the future.
   / 10 Acres of Brush #12
Hi Martin,
First, welcome to TBN.
You have almost exactly the same situation I do, including the terrain and weed species. I'm in the foothills and have 10 acres as well - got about 6 acres or so of exactly the same kind of growth you have there.
I have to mow mine two or three times a year. I consider it to be *mandatory*. The lovely green grass you see now will turn into a 6' tall mass of dead brush, which will burn so fast it'll make your head swim. There was one year that I was working a *lot* and didn't get to mowing - it was so bad I had a crew come in and do it for me.
A couple of people have already suggested it, but let me tell you... You need to get a tractor. There are services that will come in and do the cleanup for you (as mentioned), but they are expensive. It cost me $1500 the year that I let the pasture go to have it done for me (I do it in stages, chipping away at all that has to be done - they came in and did it in 8 hours).
You really do need to mow it, or at least put in firebreaks. Either one will have to be repeated every year. Renting a tractor capable of doing the work will cost probably $200 - $300 / day. In my mind this justifies the cost of a tractor - I paid $12000 for mine six years ago and the tractor still works great - and I don't pay for it any more ('cept that expensive diesel /forums/images/graemlins/crazy.gif).
Bird's advice on sizing is pretty good. That is what I wish I had bought. But what I have is quite adequate for my needs - a Kubota B7300, 48" brush hog (and some other stuff that doesn't pertain to this thread). Going bigger would be nice - a 60" deck would sure be sweet. But if you're on a budget, sticking with a 15 - 20 HP tractor can save some cash.
Anyway, if you possibly can afford it, my advice is to go for it sooner, rather than later. Put the rental money (or what you'd spend to hire someone) towards the purchase now. That way you can save yourself a lot of grief by using it to help with your one-time work as well.
Let us know what you decide to do...
   / 10 Acres of Brush #13
</font><font color="blue" class="small">( Bird's advice on sizing is pretty good. That is what I wish I had bought. )</font>
</font><font color="blue" class="small">( But if you're on a budget )</font>
Ah, yes, you know Bird had to make do with a B7100 and a 48" brush hog on his 10 acres for 4 years. /forums/images/graemlins/wink.gif And it made do pretty darned well, too. /forums/images/graemlins/laugh.gif
   / 10 Acres of Brush #14
Bird:
Egon has to make do with a 7100 too and he has no possible 2710 in his future.
Egon
   / 10 Acres of Brush #15
SLOBuds:
Judging from the photos and your general location, it looks like you are in what range managers call an Oak/Mediteranean Annual range type. Moderate grazing, mowing or frequent controlled buring will generally maintain the vegetation in it's current state. However, those annual grasses can grow pretty tall in good moisture years, and if they are not mowed or grazed, you have a real fire hazard.
I suggest you talk to someone from the California Division of Forestry or your County Extension Agent about what they recommend to reduce the fire hazard, especially if you do not have any grazing animals. If the grass is kept relatively short, then when a fire gets started, it will usually creep along the ground, rather than getting up into the crown of the oaks. However, if you have several years without mowing or without a fire, the material builds up and the brush gets thicker, so the fire ( when it comes, not if) will be a lot hotter and a lot harder to stop. Firebreaks around your buildings are a really good idea, and a tractor can be a good investment for creating and maintaining the fire breaks.
One last suggestion: Learn to recognize yellow starthistle, and if you find any of it on your property, do whatever it takes to get rid of it quick, or it will completely take over from the native plants. Again, your County Extension Agent or weed specialist is your best source of advice on treating infestations.
That really is pretty country. I enjoyed fishing in Lake Shasta when we lived out there. Good luck with your choice of a tractor.
   / 10 Acres of Brush #16
</font><font color="blue" class="small">( Ah, yes, you know Bird had to make do with a B7100 and a 48" brush hog on his 10 acres for 4 years. /forums/images/graemlins/wink.gif And it made do pretty darned well, too. /forums/images/graemlins/laugh.gif )</font>
Oh, I know exactly what you mean. My B7300 with 48" is just fine...but each time I get out there there comes a point that I think, "Boy, sure would like a 60" deck..." /forums/images/graemlins/laugh.gif
Hey, I've been using that thing for something like 5 or 6 years now - does that mean I get to upgrade /forums/images/graemlins/grin.gif?
   / 10 Acres of Brush
Thanks everyone. As usual, some GREAT comments that are very helpful.
So here is a picture of what the property looked like in November when we bought it. Considering that this exact place now is full of brush that is 2' - 4' tall, doesn't it look like someone mowed it down last year???
Most of the comments to me were fire-control related. But it seems like brush cutting would leave just as much kindling on the ground as simply letting the weeks die on their own.
This work of brush hogging is no more than a big rotary mower that leaves cut brush on the ground. Right? It almost seems like fire would be better prevented by turning the soil under with a plow or cultivator or ???
Thanks again.
   / 10 Acres of Brush #18
Welcome to TBN Martin, thats a beautiful piece of property there. To answer your question, in my opinion, unless your going to cultivate the ground and plant some sort of crop, ( hay, corn, beans, vegetables, etc.) I wouldn't reccomend that you plow or otherwise disturb the ground. The grass that is growing there will hold the land and prevent erosion (even though it never rains in California /forums/images/graemlins/grin.gif).
Mowing or bushhogging will protect the property by getting rid of the tall stems of the grass. Once cut the stems will rot and add compost to the soil. If fire is a big danger, talk to your local fire department and ask them about the type of firebreak they would reccomend for your property.
The picture you have from before you purchased the property, definitely looks as though either someone was cutting the grass or somthing real hungry was eating it. /forums/images/graemlins/wink.gif
I also agree with many of the posters here and believe you should get the tractor sooner rather than later but will add a word of caution, Tractor projects have a way of multiplying like rabbits, so be ready for all the fun!! /forums/images/graemlins/grin.gif
   / 10 Acres of Brush #19
I agree with nailerguy. The weeds and brush would initially burn easily if a fire occurred, but will rot in a relatively short period of time and no longer pose a danger. After the first mowing the gameplan would be to mow a regular basis to insure that your land doesn't generate any more "kindling."
I agree with the other folks say about getting a tractor now. Don't put off until tomorrow buying a tractor you can be having fun on today. /forums/images/graemlins/cool.gif
   / 10 Acres of Brush #20
I live in southern Minnesota so I don't know about wildfires.
You don't want to till or plow the soil. That would lead to erosion & washing on your hills. And, something always grows up again. Usually something you don't want growing - weeds.
Cutting the grass with a brush hog is like putting the grass through a blender. It will be little tiny pieces that will quickly rot laying on the damp soil & return to the soil. If you leave it standing, it will stand there a whole year, dry in the wind - waiting for that spark I suppose?
Best thing is to graze it, but that migh not fit your plans.
--->Paul
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
