10 acres and tons of ant mounds
   / 10 acres and tons of ant mounds #41
Interesting. Any idea as to the killing mechanism?
Diametceous earth - each granule is a razor sharp weapon. It will literally slice and dice anything that crawls on it or eats it.
The same principle for the food grade DE is that is will eliminate most parasites in a human when ingested as part of one diet. I.E. a table spoon or or so daily for no longer then a month.
PS when spreading it wear a mask. It is not healthy for our own lungs.
   / 10 acres and tons of ant mounds #42
Malathion kills ants very well, but we don't have fire ants here. It's cheap so you could give it a try on a small area to see how it would work for you.
   / 10 acres and tons of ant mounds #43
   / 10 acres and tons of ant mounds #44
I've treated several mounds in my pasture. I spot spray the top of the mound till lightly moist. Use Termiticide/Taurus SC found at doityourselfpestcontrol.com. Nothing I've found works as good.
   / 10 acres and tons of ant mounds #48
We have western thatching ants, similar but nowhere near as much of a problem. Small mounds that I just leave alone. The biggest bother to me is the aphid association they harvest and take onto my apple trees.
   / 10 acres and tons of ant mounds #49
I wonder if horses will graze WW B-Dahl grass?
Will it grow in South Carolina?
I lived in Charleston for a little while. Beautiful
Place. Your weather is similarl to ours except ours is more extreme on both ends. I would think B Dahl would grow fine except if your pH isn't too low.
   / 10 acres and tons of ant mounds #50
I was told that fire ants are foragers. That they need to go out beyond the mound to gather food and return to the mound with the food. So it best to broadcast the bait (AMDRO) all over the area not just around the mound.
PALLET OF PUMP MOTORS & PUMPS (A52708)
PALLET OF PUMP...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Meyer 8.5' Snow Plow w/ Bracket (A55272)
Meyer 8.5' Snow...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2107 (A58376)
2107 (A58376)
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
