Rotary Cutter 10’ dual spindle rotary mower
   / 10’ dual spindle rotary mower #1
930ck
southcentral kansas
allis d 17/ case 930, 1370/ kubota L5740
Looking at a pull type 10’ dual spindle mower and was wondering if that style takes out grass that has been ran over by the tractor better than the 6’ I have now. Seems like after overlapping to re mow what was laid down I am only mowing 4’ .
Have a 50 pto hp tractor so should have enough to use it. Would there be other issues with that style of mower?
   / 10’ dual spindle rotary mower #2
It absolutely will now much better. Higher blade tip speed. Take a good look at Rhino mowers. Excellent quality
   / 10’ dual spindle rotary mower #3
Wouldn't a 6' single spindle have a higher blade tip speed than a 10' dual spindle?
I used to have a mounted JD1008 dual spindle 10ft cutter. If you controlled your speed it cut the tire marks pretty well. Not completely though. So not sure what you expect?
I now use a JD1508 batwing 15ft cutter. So same blade length and assume blade tip speed. I use it to cut my roadbanks. I have it set pretty short and I go slow. It does a good job with the tire marks but you can still see them.
In tall grass the right tire lays it down and the blade can’t get to it , figured with a pull type twin the blades would be further back and what had been driven over would be double cut from two different directions.
   / 10’ dual spindle rotary mower #5
Makes sense.
Mower ended up being in rougher shape in person so will keep looking
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2018 John Deere 1653 (A55314)
2018 John Deere...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
