1 K
Tdog
Platinum Member
SE Louisiana
BX22
Well I reached the 1000 hour mark today on my BX-22. I looked down just in time to see it turn, so I shut her down & ran in to get my camera. Lots of bruises & scrapes on it now, looks very used, which it is. I bought it new April 25, 2003, so it's not quite 5 years old.
Jack
Have you had any problems in the last 1000 hrs? With your bx
Congratulations!
I like your hour meter. On my '07 BX24, I have the "improved" digital hour meter that appears for a few seconds when I'm cranking the engine over, then it switches to a tach. I wish Kubota had kept the analog displays. Needless to say, I won't be taking any pictures of my 1,000 hour rollover.
/ 1 K
ficord - - I have not had any problems to speak of. At least not any I can blame on the Kubota failing. I could, however, horsewhip the engineer that left the little transmission cooler fan so exposed underneath. After I paid $$ to have that replaced I purchased the Bro-Tek belly shield. The BX-22 was a good match for my needs. I will admit that I sure could have used a larger machine while cleaning up after Katrina.
Compadre - - I didn't know they had changed the display. I wish mine had come with a tach but I don't like the set-you described.
Jack
Jack I don't want to be too critical, but I noticed there is some dirt around the hour meter and gas gauge that should be cleaned if you expect to reach 2K on that rig.........congrads! Darn you must be driving that thing around town to put that many hours on it.
/ 1 K
Geez, Wayne - - I cleaned it up before getting the camera!
Jack
Compadre said:
Congratulations!
They should simply set that to a multi display that programs its own EPROM to user preference. Like the Tiny Tach (that's what I have to supplement a lack of a tach). One might have it default to tach, while another to hours. I especially like the Service alarms and Job timer on the Tiny Tach. Kubota should just build those units in or opt for their own design. Back lit, for one! Hint, hint!:rolleyes:
Jack
Notice I didn't put a pic of my B7500 showing just how dirty dirty can be. 3 degrees this morning so it will be a few months before we can go out and do any washing out doors.
By the way how does your tractor do with the tiller you have? I have a Howard rotavator, just bought but won't be doing any tilling until late april around here.
/ 1 K
Well Wayne, I don't have any experience with any other tiller except the Craftsman walk-behind I used to have. The Yanmar works great compared to the walk-behind. It will turn the garden to powder if you make enough passes. I bought it VERY used for $400 about 2-3 years ago. It's got some rust on it & it is ugly. Some previous owner had spray painted it with primer all over. I got it to smoking once when I first got it - - that's how I learned how a slip clutch works.
Don't quite know when I'll start my garden - - we may have had our last freeze of the year, but I'll probably wait till mid March.
Jack
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
Texaco Gas Pump Yard Art (A64557)
Texaco Gas Pump...
