'07 B series rumor mill?
/ '07 B series rumor mill? #41
O.K., I'd like to widen this topic a little. I have hard packed clay on top of concrete like hardpan. At the interface, the claypan becomes harder and harder. The pan surface undulates and the depth through the clay to the hardpan varies greatly.
Recently I used a single tooth sub-soiler on my BX2200 to rip some of this stuff so that a dozer towed carry-all pan scraper could move some soil. In some places, the tooth dug in adequately and in turtle range I could inch along, ripping o.k. In other places, the BX just didn't have the power to pull through. In some places the tooth would submarine lower than I had set the 3ph, in others, it would stay put. I put the old girl through her paces, often getting a running start then lowering the tooth just before reaching the most recently ripped point.
Someone mentioned draft control being a whole different topic than position control. I've seen some plows with small adjustable height wheels. Is this the only method of draft control, or do some 3ph's have an internal mechanism to prevent the cutting bit from submarining?
/ '07 B series rumor mill? #42
My International had draft control. It basically is a hydraulic valve operated via a lever sytem which is part of the toplink 3 pt hitch assembly. It raises the 3pt hitch when the draft valve is triggered. Once the load dimishes, it allows the 3 pt hitch to go back to the position levers pre-determined spot you selected. It works very well. While I have had very little need for it, there are those that do. On my L3830, it is an option. You can adjust the sensitivity of it by changing the toplinks attachment point. That changes the leverage the link places on the hydraulic draft valve and how quickly it reacts.
/ '07 B series rumor mill? #43
On your BX2200 you'll need a gauge wheel to replicate draft control. I have a long description somewhere on how draft control works but basically the 3PH system has to be designed for draft control meaning it can't be added.
My old Ferguson TE20 had draft control and it worked pretty good when plowing. Harry Ferguson developed draft control on his tractors and partnered w/Henry Ford to add it to his 2N/9N and later 8N tractors.
It worked off of the top links ability to change the point of attack of the tip of the plow by varying the length of said top link. This was accomplished by the top link's connection point on the rearend. The top link connects to a pivoting bracket that is held in place and kept static via a very large spring. The spring can compress and/or expand, lengthening or shortening the toplink dependant upon the forces applied to the plow whilst plowing.
Anyways, you'll need a depth wheel and a quick hand to replicate draft control on your BX.
/ '07 B series rumor mill? #44
I don't think you need anything. Just set the lowering speed to slow and drop the impliment to the depth you need, then quickly move the 3 point control lever to the center position and the impliment will go no lower. Changing the length of the top link will change the angle of attack for a more or less aggressive bite.
/ '07 B series rumor mill? #45
The CCM hydraulic toplinks and side links with double piloted check valves will arrive at CCM on Monday April 2. Please give us a day to check them in before you call and place your order. We will start taking orders Tuesday April 3. ALL sizes should be available.
Thank you for your patience and support.
Mark Carter
/ '07 B series rumor mill? #46
And now the rush is on. For any of you debating, I have this top 'n' tilt set-up, it is the way to go. Add TNT to position control and you have it all for 3 point in a small compact tractor.
/ '07 B series rumor mill? #47
Any information on the replacement for the B7800 to be introduced at the Oct. dealer meetings? hp pto etc?
Thanks, Mark
/ '07 B series rumor mill? #48
Tom:
Draft control is one of the revolutionary inventions conceived by Harry Ferguson in the 1930 and subsequently adopted by all manufacturers of farm tractors after the Ferguson patents expired.
Oversimplified, it is a method of controlling the draft of an implement by using hydraulic control, and it allows a lightweight tractor to pull a ground engaging implement that it would not be able to pull due to lack of traction otherwise.
Its usefor plowing is nearly universally but who plows anymore.
Aside from ground engaging implements is it normally not used or needed, and is not found on most compact tractors.
Dean
/ '07 B series rumor mill? #49
And the brush hog has a gauge wheel to adjust height.
Can someone please confirm the accuracy of this statement which, to me, makes perfect sense. For any rear implement that has its own gauge wheels, it should not matter which control your PTO has. You just drop the PTO to its lowest setting, and the gauge wheels will assume full determination of the operating height.
I hope this is true. I expect to buy an older, *used* Kubota tractor and a new Woods RFM. I prefer a simple application for mowing. Drop and go is the type of simple I am hoping for.
Thanks,
The Gardener
/ '07 B series rumor mill? #50
Thanks,
The Gardener
Most Rotary Cutters only have a tail wheel. To control how low front end of Rotary Cutters drops. The 3PH needs to stop in the same position every time.
If you want a Drop and go setup. Then put position control near top of the list of items that you want on the tractor.
Here is a list of abbreviation that are commonly used on TBN. Should help you understand some of the replies better.
Glossary of tractor terms
/ '07 B series rumor mill? #51
Gardener:
All modern tractors with a three point hitch have position control. Few or no compact tractors have draft control nor is this needed unless you wish to plow.
If you want to "drop and go" with a three point rotary cutter buy any tractor with position control, e.g., just about ANY tractor and an appropriately sized mower.
To make your life just a bit easier, install limiter chains on the mower.
Dean
/ '07 B series rumor mill? #52
SDT said:
Gardener:
to make your life just a bit easier, install limiter chains on the mower.
Dean
With any three point hitch it makes for an accurate height adjustment that you can;t get with any other system.
Any mower should cut on the front!
/ '07 B series rumor mill? #53
SDT said:
Gardener:
Dean
Except the BX Kubotas, the B7510, 7610, 7800, etc. That makes for a pretty significant sector of modern tractors that don't have position control, and a pretty sizeable portion of annual compact and subcompact tractor sales.
/ '07 B series rumor mill? #54
My decision is made ... I will look to a tractor with either a MMM or a RFM to handle our 7+/- acres of lawn cutting. And, I am going to be certain that the PTO has "position control". It definitely matches my inexperience level. And, I think it would have better re-sale value should that become important.
I'll certainly look into the limiter chains, but I don't imagine that type of exactness and accuracy will be needed on the acres that I'll cut with this tractor. I'll still use our 42" riding lawn mower to handle the immediate lawn around our house, the gardens, and the barn, and perhaps a couple of super laps around the entire woods line to handle the cutting under the over hanging limbs. That equates to about 20 +/- minutes of cutting.
By time we are ready to make this purchase, there should be some very nice B3030 tractors on the used market which would be perfect for our budget.
/ '07 B series rumor mill? #55
Mr. White said it all here!
Check chains to limit downward movement..
Like they say in the Ronco commercials..."Set it and Forget it"..
Alot cheaper and more accurate than Position control.
/ '07 B series rumor mill? #56
There are some very nice B2910's around used, with low hours, and they have all the bells, and whistles including position control. Don't overlook them in your search...... very comfortable machine, and the same size as a b3030
/ '07 B series rumor mill? #57
PTO= Power Take Off. Turns the shaft supplying power to mower or attachment.
3PH= Three Point Hitch. Raises and lowers attachment. Position Control is part of this system.
As already stated. There are many B2910 out there that will meet your requirements. A 72" MMM on this tractor will cut 2 acres of lawn per hour.
/ '07 B series rumor mill? #58
Provided that lawn is nice and smooth. 72" MMM + uneven terrain = bad plan. 60" MMM handles it better and as a result gives about the same productivity.
/ '07 B series rumor mill? #59
Rumor addition.... BX 2650 is coming next year.
/ '07 B series rumor mill? #60
Boy this has got to be the best example of hijacking a thread I have ever seen.
On 12-8-2006 WayneW ask:
Has anyone heard of an '07 (or '08?) replacement to the aging B7800?
On 12-12-2006 WayneW ask:
So no one has heard of a B7810 in the works?
On 7-6-2007 Markanth ask:
58 replies, not one direct answer, 99.9% replies are about quarter inching valve Vs position control.
Just so WayneW can have one answer: I have not heard of an '07 (or '08) replacement to the aging B7800. Of course they dont let me out of the home much anymore, so I really dont know.
2022 EZ-GO ELITE...
John Deere CP690 (A64126)
John Deere CP690...
H&S BF 1460 Rake (A63688)
H&S BF 1460 Rake...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
