'06 John Deere Trail Gator
   / '06 John Deere Trail Gator #1
kkilpatrick
\'06 John Deere Trail Gator
If I go to larger more aggressive tire what kind of power loss can I expect to experience?
   / '06 John Deere Trail Gator #2
Re: \'06 John Deere Trail Gator
I have an 05 HPX Trail Gator. It is geared pretty low so I would think larger tires would be ok. As far as a more aggressive tire, is there a more aggressive tire?
dsb
I have looked at Swampers, Gators and Mud Lite all have a very aggressive tire. I'm looking for more gound clearence that a taller tire can bring more than anything else.
   / '06 John Deere Trail Gator #4
I have ITP Mudlites on my 2005 diesel Gator. They are larger in circumference and much more aggressive than the stock tires, and I can perceive no loss of power with them. That said, I have not had the stock tires on this Gator. I demo'd a gas model and decided on the diesel, but I think either would handle a moderately more aggressive and larger tire fine. The one other thing to think about: I went with the same size all around, rather than the smaller fronts as with the stock Gator. It really enhances the look and adds a bit of front ground clearance, plus you can rotate the tires based on wear.
John M
What size Mudlites did you go with?
   / '06 John Deere Trail Gator #6
Have you had any problems getting it into and out of 4x4? Having the same size tires front and back may put your driveline in a bind, although it might not make a difference if you're in mud and the wheels can slip.
I only have seven hours on my Gator but I have had no problems except a flat tire due to a thorn that worked its way in. The new 4x4 switch on the dash works great. I also own an '85 4x4 truck. When you unlock the front wheel drive you put it in reverse for a few feet to unlock the hubs. John Deere recomends this also. I have practiced that procedure for a long time. It works well with the Gator also.
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
Year: 2022 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 6,257 Plate: Body Type: 2 (A51692)
Year: 2022 Make...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
