04 f250 ford 6.0 PS DTC codes / ABS light
   / 04 f250 ford 6.0 PS DTC codes / ABS light #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
abs lamp came on the dash today.
my first check was to make sure the front r/l wheel speed sensors hadn't come unplugged. nope.
may pull them to clean them.. but pulled codes with my superchips tuner scanner to see what was hanging around in the computer.
pulled 3 dtc's
.. unfortunately none were from the p0500 and up where I thought they would be for a speed sensor
the 3 pulled I knew about and have to do wuth an egr / turbo issue under observation.. ;)
do wheel speed sensors set codes for the abs lamp on the dash.
any other ideas i could look at for the source of that abs lamp?
thanks
soundguy
   / 04 f250 ford 6.0 PS DTC codes / ABS light #3
Ah, i see you edited your post. I do believe a misbehaving sensor will cause the abs light to come on.
yep the other 3 are related to an egr issue that is under observation right now... i plan on pulling the wheel speed sensors and cleaning them and see what I get. new ones are about 130-150$ a piece and order items.
12 in Small Excavator Bucket (A52377)
12 in Small...
2020 BOBCAT T76 R-SERIES SKID STEER (A51246)
2020 BOBCAT T76...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2014 INTERNATIONAL LF687 SLEEPER (A52576)
2014 INTERNATIONAL...
Electric Concrete Mixer (A51573)
Electric Concrete...
