'04 4320 performance chips?
/ '04 4320 performance chips? #1
Rob52
Mid Mich
2005 John Deere 4320
Anybody know where to find performance chips for JD 4020 series? Do they may them? Are they worth it?
/ '04 4320 performance chips? #2
Ahh, the Holy Grail. Instant 4720 in a box. Doesn't exist in this world and probably never will. However..... there is always hope. :)
/ '04 4320 performance chips? #3
Does anyone know what JD does to make the incremental changes between models? All the specs seem to be the same between my 3520 and the 3720, yet the "7" has more HP. More boost to the turbo? Or has it been "chipped" in some way to get those few more HP's? They're doing something. Its plain they add the turbo between the 3320 & 3520, but the same situation holds true between the 3120 and 3320.
/ '04 4320 performance chips? #4
The 3720 has an intercooler whereas the 3520 does not.
/ '04 4320 performance chips? #5
Wow,
So if can scoop an intercooler someplace, I can gain 7HP? I mean that's worth the quest. I didn't think there was that much gain to be had, but keeping things cool is an honorable pursuit.
Do you know what the boost pressure is and is it the same on both (37xx vs 35xx) - or do they play with that too?
/ '04 4320 performance chips? #6
The cool(er) air by itself won't do much by itself- you need more fuel too. I don't know if they are getting the extra fuel by increasing pressure or via injector duration.
My guess is that the turbos are the same and the extra power comes from the intercooler/fuel changes. Maybe someone with more/better knowledge will come along and give us some facts vs my speculation. :)
/ '04 4320 performance chips? #7
There is a good deal more complication in the difference in engine set up other than just an intercooler. Additional fuel, timing differences as well as "chip" or computer changes that would control all sorts of other different engine parameters. There are a couple of other threads on the site that have documented some of this. Although I am sure that there is a path that could be taken, no one so far has admitted to having the know how. John Deere is very protective (and rightly so) of the actual differences between the machines and how they bring it about.
/ '04 4320 performance chips? #8
joebobharley said:
There is a good deal more complication SNIP. John Deere is very protective (and rightly so) of the actual differences between the machines and how they bring it about.
Thanks for the info. I popped for the 3520, over the 3320, just because the HP jump/$$$ seemed well worth it. I'm just a HP (actually torque) junkie from way back.
/ '04 4320 performance chips? #9
The injectors aren't computer controled on these so a chip won't do any good.
I'm working on giving my 3720 some more snort...
2005 John Deere 7420 (A60462)
2005 John Deere...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2019 Ford F-250 Ext. Cab Pickup Truck (A61573)
2019 Ford F-250...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
Location Tampa, FL (A61567)
Location Tampa, FL...
