02 Yamaha raptor won't start
   / 02 Yamaha raptor won't start #1
robs660
Washington NJ
Kubota B20
Here are the details
- Has not been run since 2007 when starter clutch failed
- Replaced starter clutch and 52 tooth gear
- Changed oil
- Cleaned carbs
- Drained fuel tank washed out with fresh gas till it ran clear
Issue - Will not start. Starter will turn over however - the relay will click at me if I try too much, or too long.
Starting off a new tractor sized battery that I know is good.
With spark plug removed the motor turns over without any issue.
Can not test the spark tonight because my tested does not fit the plug. I did remove and clean the plug.
I have gotten a few back fires during this process but she will not start.
Any thoughts????? I really want to go play on my neighbor's track with my friends
   / 02 Yamaha raptor won't start #2
Not to be an idiot...Check you kill switches and make it is turned on...I've seen this happen before.
Is the plug getting wet or do you smell gas after all of that cranking?.
You don't need a tester to check for spark. Just take the plug out and lay it on the head..Should see a nice arc.
Try priming it with a small amount of gas.
If it starts and runs for a short time, you have a fuel delivery problem most likely.
Those are the bare basics..There are alot things to check if need be.
Kill switch is on
I will check plug in am
thanks
She lives. Just needed a new battery. Raced it yesterday. Cold as ****!
HUSQVARNA RIDING...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2001 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A57880)
2001 GMC C7500...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
