02 Yamaha raptor won't start
   / 02 Yamaha raptor won't start #1
robs660
Washington NJ
Kubota B20
Here are the details
- Has not been run since 2007 when starter clutch failed
- Replaced starter clutch and 52 tooth gear
- Changed oil
- Cleaned carbs
- Drained fuel tank washed out with fresh gas till it ran clear
Issue - Will not start. Starter will turn over however - the relay will click at me if I try too much, or too long.
Starting off a new tractor sized battery that I know is good.
With spark plug removed the motor turns over without any issue.
Can not test the spark tonight because my tested does not fit the plug. I did remove and clean the plug.
I have gotten a few back fires during this process but she will not start.
Any thoughts????? I really want to go play on my neighbor's track with my friends
   / 02 Yamaha raptor won't start #2
Not to be an idiot...Check you kill switches and make it is turned on...I've seen this happen before.
Is the plug getting wet or do you smell gas after all of that cranking?.
You don't need a tester to check for spark. Just take the plug out and lay it on the head..Should see a nice arc.
Try priming it with a small amount of gas.
If it starts and runs for a short time, you have a fuel delivery problem most likely.
Those are the bare basics..There are alot things to check if need be.
Kill switch is on
I will check plug in am
thanks
She lives. Just needed a new battery. Raced it yesterday. Cold as ****!
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
1459 (A57192)
1459 (A57192)
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
