'02 Jinma JM 354 Steering Issues
/ '02 Jinma JM 354 Steering Issues #1
bjr
Veteran Member
Eastern WA
Jinma JM354
Last nite, After mowing the neighbors pasture, I was heading home on the street and the steering wouldn't respond. I mean the steering wheel turned as usual but the front tires did not respond. A couple of months ago I put end joints on the steering cylinder had checked the tie rod ends and all are operational then. When I got home, driving very carefully, I checked all joints and linkages and everything seems fine. I'm thinking some oring or bypass valve spring somewhere in the steering hydraulics broke. Any help will be appreciated. Where should I start trouble shooting? bjr
/ '02 Jinma JM 354 Steering Issues #3
Yeah, what Tommy said. Check the fluid reservoir in front of the radiator first. If that is full, then disconnect the steering cylinder at the Pittman arm end and try turning the steering wheel. If the cylinder now operates, it is probably bypassing fluid and needs to be rebuilt. If it doesn't operate at all, disconnect the hydraulic hose that runs from the steering pump to the steering motor and place it in a bucket then start the engine. If the pump is good it will pump fluid into the bucket; if no fluid, the pump is possibly bad. The least likely thing to go wrong is the steering motor failing, but it can happen. Just not as often as the cylinder bypassing or the pump going bad.
/ '02 Jinma JM 354 Steering Issues #4
BJR, My Dad had a problem with his foton 904 steering. It had a small leak at a hose clamp. I don't know if it ran too low on fluid or sucked air in at the leak, but we figured out after tightening the clamp up, that the system had air in it. I bled the air out with the tractor running at idle I loosened the hydraulic lines going to the steering cyclender till I had a steady small stream of oil then tighten them up. Almost immediately it began to work like it should again. Hey its worth a try before going thru all the other work. Lildobr
Well a little update. I got the seal kit from Ranch hand, installed and promptly blew the oring on the rod seal, the outer diameter oring. I also had a stuck bypass plunger valve on the pump. Removed pump cleaned bypass and reassembled. I was able to replace oring by removing rod end ball joint and unscrewing the packing nut. I didn't have remove the whole cylinder this way. Finally reassemble all and filled with new oil and it operating just fine, now. bjr
/ '02 Jinma JM 354 Steering Issues #6
Glad you got it going,and thanks for posting the fix.
2008 GMC W4500 4X2 14FT BOX TRUCK (A59906)
2008 GMC W4500 4X2...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2025 MMS MS36C (A60463)
2025 MMS MS36C...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2011 John Deere 995 (A60462)
2011 John Deere...
