PTO problem
/ PTO problem #1
MSman
Gulf Coast, MS
Cub LT1045
16 hours on my 1046 and the PTO was operating normally. While mowing, it disengaged, clicked a few times when I tried to re-engage it. Then it stopped the clicks and now nothing happens. Is there a relay, fuse, etc. that might be bad? I noticed a while back, when replacing the deck belt, that the PTO was warm, not touching it but just having my hand near it. Is this usual? Any suggestions will be appreciated.
/ PTO problem #2
Try this, thump the relay that is taped to a fuse by your right knee while sitting in the seat, I had to do this on my 1042 while waiting to get to a parts store. I replaced the mini relay, and havent had a problem.
/ PTO problem #3
The PTO clutch is an electromagnet, and the coil will get warm when it is engaged. Don't forget to check the dreaded safety switches if the relay or fuse are OK.
-Fordlords-
/ PTO problem
Found the problem, I think. The spring that goes to the idler pulley is broken and allows the pulley to go foreward and butt up against the other pulley. This is the rear spring. Now if only I can find a replacement-since I live in the boonies far from any dealer. I don't know if this is a covered by warranty or not since it looks expensive.
/ PTO problem #5
-Fordlords-
ok, thank you, will try it .
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
New/Unused Landhonor 50 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
UNUSED WOLVERINE TQH-26-01C 3PT. TRAILER MOVER (A62131)
UNUSED WOLVERINE...
2016 Land Rover SUV (A61569)
2016 Land Rover...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
