They do look like cross chain hooks.
Also, from what I’ve seen those light duty flail knives are typically mounted with a bolt to the tabs on the rotor.
Can anyone help Me ID this mower? It's for sale nearby, owner can't tell me what make or model (red flag #1). It's short money and he says it works, so it could fit the bill for a cheap pond bank mower for me. I just want to be sure it's not pure crap to begin with.
It looks a lot like many of the generic Chinesium units coming over. Brand ID will also help me determine actual value. ETA- 60" width
ETAA- It's a victory unit from what I can tell.
Any help appreciated!
See if the seller is willing to hook it up and run it. Otherwise you may be buying aI just want to be sure it's not pure crap to begin with.
I noticed there was no demo of mowing a ditch or bank ... ???Here's a video on it:
The hydraulic lines on the swing out function tend to get pinched and split. They are heavy...mine is almost 1000 lbs.
I've got a heavier tractor, A Mahindra 2665, which is north of 5000lbs with the FEL on it. The BCRM-175 is 985lbs, or about 20% of the tractor's weight. I've already reversed the rear rims for another ~5-6" of track width. I'd go narrower, but the 61" is only 40 lbs lighter, and I lose the reach down the bank I need. Anyone have a similar setup. weight-wise, and how did it behave? I want to hang the flail off the side down a 45 degree bank around my pond. Basically a flat-topped donut berm with steep banking on either side.Victory is almost (is?) the same as Nova Tractor. I have a BCRM 175.
With the hammers, they eat brush like Mikey eats Life cereal.
My T574 is similar, but no cab. I'd load the tires if you haven't. Also, play around with the adjustments before you actually try the shift over an embankment.I went ahead and ordered the BCRM-175 yesterday. Added the belts and extra hammers for about $3500 all in.
Looking around, even the used Del Morinos available within a sane distance were twice that. Hopefully, I can use the collected knowledge here to avoid the more common issues.
