TR3 $4000 vs LandPride $1500
/ TR3 $4000 vs LandPride $1500 #1
Tifford
Jordan
Mahindra 25 hst
TR3 that sells for $4000
Or LandPride that sells for $1500.
Which of these two for a half mile single lane dirt road that has pot holes and is fairly hard packed? Road needs a crown. The Tr3 is 6 feet wide and the LandPride is 4 feet wide.
Tractor is a 25 hp mahindra with hydrostatic drive. Which one?
/ TR3 $4000 vs LandPride $1500 #3
I would go with the LandPride land plane, but would probably go with a 5' one.
Leaning heavy towards the Land Pride. Got to find a dealer in my area that has one.
/ TR3 $4000 vs LandPride $1500 #6
Also Land Pride. (y)
/ TR3 $4000 vs LandPride $1500 #7
I have the Land Pride 5' grading scraper behind my WM25, along with the LP15 Quickhitch for additional weight on the 3PT.. It works great to keep my 700' driveway in shape. Driveway has recycled asphalt millings on it. The TR3 was originally an arena drag that they now market for doing driveways. In my opinion it won't dig in to hard packed material like a grading scraper will, especially one with scarifiers.
/ TR3 $4000 vs LandPride $1500 #9
I would think the land plane would be a better choice, that being the Land Pride; that said, you want to make sure it covers your machines tire tracks. So probably a 54 or 60 inch.
/ TR3 $4000 vs LandPride $1500 #10
First off - regarding the Land Pride - land plane grading scraper ( LPGS ). It makes VERY LITTLE difference if the unit is as wide as your rear tires or not. The LPGS is NOT used to cultivate your land and as the rear tires will pack down what the unit has skerfed up - so much the better.
I have a large, heavy Land Pride ( LPGS ). 84" wide and 830 pounds and with scarifiers.
As a road maintenance implement - the LPGS is not designed to create a crown on a gravel road. And - true to its word, it does not. It will lift the top inch or so of a gravel driveway and lay it back down. Adjusted properly - the driveway will be smooth as a babies bum.
Crown is created with a blade implement that can move material from the side to the center of a gravel road. To this end - I use my 1000 pound Rhino rear blade.
That "thing" in the top picture MIGHT be heavy enough to smooth sand on a beach. Properly adjusted the Land Pride will do the job you have. Particularly since you say the driveway is fairly hard.
Even on the hardest part of my mile long gravel driveway - I only set the LPGS to cut the top inch or so. If I have a serious pot hole - drop the scariffiers and fix the pot hole.
My Kubota M6040 has more than sufficient power to pull the scariffiers through the hardest soil. And - believe me - my driveway "sets up" just like concrete. It's a mix of gravel, sand, silt and volcanic ash.
/ TR3 $4000 vs LandPride $1500 #13
I see similar implements as the TR3 used for dressing the sand in a riding arena but not on a driveway. A chain harrow would do a driveway better and could also be used in an arena. If you're looking to fix up the driveway the landplane is the better tool for the job. Mine looks like I had gravel brought in when its done
I just agreed to the Land Pride lane plane gs0560. 5 feet wide. Picking it up Friday.
Between it and my 4ft box blade with rippers I should be in business.
Thanks everyone for chiming in.
