I’m looking at this tractor with loader.
It has about 2800 hours - more than I’d like but seems to be a good price.
Thoughts anyone?
And thanks in advance.
Dawg in Fl
What are you going to use it for??
I have a 5103. About the same tractor but 50 HP instead of 64 HP.
It's a pretty good tractor for doing hay with a small square baler. Frankly, I think that's about the best use for it. I use it to pull a baler, rake hay, and run a tedder. However it would be nice to have more options for range / gear combinations.
It's not great for loader work. Too much shifting gears and not much fine control. The loader works smooth though and is strong. But you'll be spinning the back tires as soon as your bucket starts to push into a pile -- if you have 2 WD.
Mine has the crappy JD bucket attachment instead of SSQA. I wouldn't buy anything again that's not SSQA. The loader also is not a quick-detach model. I drop the bucket or forks when not needed just to shorten things up and lose the weight. But I can't drop the loader itself. (EDIT -- in fairness, I rarely remove loaders that I can remove. Usually just drop the front attachments.)
Mine is not 4 wheel drive. It does good out in the field, but you can get it stuck in snow or mud pretty easy.
Mine has R1 tires. Rides smooth. Steering is nice and tight. Starts almost instantly every time. Not bad on fuel -- much better than a similar size Kubota. I like the flat fenders -- better for mounting a tool box, etc. than the round fenders on their higher end tractors.
If you plan to do a lot of loader work, especially in tight spaces, you'd do better to get something that's hydrostatic or shuttle-shift or something besides a straight 3 gear tractor.
It has served me well, but I'd like to replace it with something that's hydrostatic or shuttle-shift and 4WD with a SSQA loader.
That's my opinion, FWIW.
