Changing PTO switch
/ Changing PTO switch #1
hhundt
Lake Park, MN
None
I am changing out a broken PTO switch, and a newby at wiring. The new switch wiring diagram PT sent me doesn't match how my old switch was configured (PT-2430). (See attached picture) Would I have the wrong diagram, or did the manufacturer (Cole Hersee) change the switch? Also the colors of the wiring is different in my unit than in the diagram (eg, orange vs yellow). I didn't include the entire diagram in the photo, but followed the wires on the diagram. Would the "Black Jumper" on the diagram be the black/white striped wire? It's a rats nest of wires in the tractor so not sure where they all go, I'll dig more to track them later. Going to call Terry next week but wanting to get more information to learn about all this before so I am not so confused. Yahoo is not helping :D. Thanks!!
/ Changing PTO switch #2
That's a standard DPDT switch, so with the switches in the same positions, if you get the wires on to the matching corners and center points, you should be fine. I agree that there is next to no room in there on mine. I take off all the panels before I do anything.
When I replace switches like that, I take good "before" photos, then move one wire at a time, and then check my work.
Does that help?
All the best,
Peter
/ Changing PTO switch #3
Does that help?
All the best,
Peter
Yep. Take photos first. Or make a paper diagram before removing any wires.
Then transfer one wire at a time from old switch to new switch. Test before you button everything up.
Thanks All! It helps a lot. I marked the wires and their contacts with dabs of paint before I took them off, so know how to replicate the order. I'll go ahead and put the new one in the same order and see if it works, my original plan. I was just confused with the wiring diagram and didn't want to jump in right away.
