I'm looking at an SAE to NPT adapter on Summit Hydraulics, they offer NPT size as choices as #8 NPT or #10 NPT. I thought they came in fractional sizes.
Can anybody explain please?
Thanks
The screen shot does not agree with itself. It calls out 3/8 Jic x 3/8 NPT -- That would be 6 - 6. ....... Then it says its an 8-8.This is what i was looking at.
I get the bulkheads sometimes if I need to increase the connector length.Hydraulic fittings are pretty much sized this way across the board. JIC, ORB, ORS and NPT as well. What are you building, repairing, etc. that you are using a bulkhead fitting on? When mounting in brackets, or through cab or enclosure walls they work well for being able to securely mount solidly. Here is your fitting on Amazon. Here also is a link for a Good reference to find the fittings you need. The other thing is that with some minor changes like an added letter or two fittings use standard part numbers as well.
AF 2706-08-08 - #8 Male Pipe (.840''-14 Threads) X #8 Male JIC 37 Degree Flare (3/4''-16 Threads) Bulkhead: Amazon.com: Industrial & Scientific
AF 2706-08-08 - #8 Male Pipe (.840''-14 Threads) X #8 Male JIC 37 Degree Flare (3/4''-16 Threads) Bulkhead: Amazon.com: Industrial & Scientificwww.amazon.com
It's updating, they just have it labeled poorly. Here's a link to the item in question. Adapter, JIC Male x NPT BulkheadThe screen shot does not agree with itself. It calls out 3/8 Jic x 3/8 NPT -- That would be 6 - 6. ....... Then it says its an 8-8.
I think that website is not updating as it should as you make choices. I would get on the phone to make sure of what I was getting.
That is how they work.It's possible that it's a blended thread with taper at the end and straight for the nut, assuming that actually works.
